Unable to understand the time unwanted time taken by cudaDeviceSynchronise()
My application is written to do inference for a custom segmentation model. When I profiled the application using Nsight Systems, I found that the cudaMemCpy for device to host was taking around ~33ms whereas the host to device copy was under 1ms. I read some articles which suggested the use of cudaDeviceSynchronise() to seperate the kernel execution time. When I added that to the my code, the cudaMemCpy for device to host greatly reduced to be <1ms but the cudaDeviceSynchronise() was taking up almost 33ms now.
Here’s the timeline view after adding cudaDeviceSynchronise():
Here’s the code:
cv::minMaxLoc(cpu_img, &minVal, &maxVal, &minLoc, &maxLoc);
cpu_img.convertTo(cpu_img, CV_32FC1);
cpu_img = cpu_img / float(maxVal);
cudaMemcpyAsync(buffers[0], cpu_img.data, sizeof(float) * dl_input_size * dl_input_size, cudaMemcpyHostToDevice, stream);
context->enqueueV2(buffers.data(), stream, nullptr);
cudaDeviceSynchronise();
std::vector<float> cpu_output(getSizeByDim(dims[0]) * batch_size);
cudaMemcpyAsync(cpu_output.data(), (float*)gpu_output[1], cpu_output.size() * sizeof(float), cudaMemcpyDeviceToHost, stream);
std::vector<float> cpu_output_landmark(getSizeByDim(dims[1]) * batch_size);
cudaMemcpyAsync(cpu_output_landmark.data(), (float*)gpu_output[2], cpu_output_landmark.size() * sizeof(float), cudaMemcpyDeviceToHost, stream);
cudaStreamSynchronize(stream);
There is no call like that. I guess that is not actually your code. It is spelled with a z not an s.
To understand the time that is now taken by cudaDeviceSynchronize(), you need to understand that the work you issued to the GPU does not execute in zero time. It takes some time for the work to execute, and since the GPU executes asynchronously, the time of execution appears at the cudaDeviceSynchronize() call.
The work you are asking the GPU to do here:
takes time. It does not execute in zero time. If you immediately follow that call with cudaDeviceSynchronize(), then that is telling the host CPU thread “wait here until the previously issued work to the GPU has finished” and so it waits there, and you see the execution time of the inference request at that point.
