I may well be wrong, but it seems that CUDA 3.1 is not able to compile this on sm_13:
#include <stdio.h>
#include <stdlib.h>
#include <assert.h>
#include <cuda.h>
__device__ unsigned int atomic_cnt = 0;
__device__ int queue_fetch()
__shared__ bool amFirst;
__shared__ bool amLast;
const uint id = threadIdx.z + threadIdx.y*blockDim.z + threadIdx.x*blockDim.z*blockDim.y;
const uint nblocks = gridDim.z*gridDim.y*gridDim.x;
if(0==id) {
unsigned int ticket = 0;
ticket = atomicInc(&atomic_cnt, nblocks);
amFirst = (ticket == 0);
amLast = (ticket == (nblocks-1));
__syncthreads();
// other code here which was removed to simplify it
return 0;
__global__ void kernel()
queue_fetch();
int main()
$ nvcc -V
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2010 NVIDIA Corporation
Built on Tue_Jun__8_18:56:17_PDT_2010
Cuda compilation tools, release 3.1, V0.2.1221
$ nvcc -arch=sm_13 -c test.cu
test.cu(8): warning: variable “amFirst” was set but never used
test.cu(9): warning: variable “amLast” was set but never used
ptxas /tmp/tmpxft_0000671b_00000000-2_test.ptx, line 0; �%J�Y: (C6017) Unaligned access for GRF[0] (unknown symbol) in entry ; the offset should be 4-byte aligned.
while CUDA2.3 is able to compile it.
any ideas?
avidday
September 6, 2010, 10:58am
4
I initially thought that as well, but changing the pair of shared memory booleans to a 32 bit type doesn’t help. The ptx it generates looks OK to my inexpert eye, but the assembler is choking on something.
avidday
5
I think it was suggested in the other thread that the if statement somehow causes this… the OP also has if statement in his code.
eyal
eyal
judging from the weird output, I really think that there is a bug inside ptxas, which has that print as a side effect.
just look at the chars after the “line 0:” part, and the “”
it may be in a ptxas code path related to the sm_13, which I think is much less tested nowadays
For developers targeting primarily compute 1.x devices there are currently not a lot of good reasons to update to the 3.0 and 3.1 toolkits.
#include <stdio.h>
#include <stdlib.h>
#include <assert.h>
#include <cuda.h>
if(0==id) {
__syncthreads();
return 0;
queue_fetch();
int main()
any ideas?
You are not going to believe this:
Leave out gridDim.z in the nblocks declaration and it will compile (1.3 on 3.1).
Afaik gridDim.z is always 1 on 1.3?
#include <stdio.h>
#include <stdlib.h>
#include <assert.h>
#include <cuda.h>
if(0==id) {
__syncthreads();
return 0;
queue_fetch();
int main()
any ideas?
hey… that’s right! nice spot!
now I understand why a similar construct is ok in another code…
thank you so much!
thank you so much!
njuffa
September 7, 2010, 9:30pm
16
Thank you for bringing this issue to our attention. I was able to reproduce the problem on 64-bit Linux (RHEL 5.3) with CUDA 3.1. Interestingly it does not reproduce on 64-bit Windows (the code won’t compile however because “uint” is undefined). I will follow up with our toolchain team.
njuffa
17
