CUDA 3.1 compiler crashes trying to compile my projects. What is worth to check?
/home/john/projects/CPM/include/WarpStandard.cuh(78): Error: Unaligned memory accesses not supported
*** glibc detected *** /usr/local/cuda/open64/lib//be: double free or corruption (out): 0x00000000015d05e0 ***
======= Backtrace: =========
/lib/libc.so.6[0x2ade921e62f6]
/lib/libc.so.6(cfree+0x6c)[0x2ade921eac6c]
/usr/local/cuda/open64/lib//be[0x5e3ef5]
/lib/libc.so.6(exit+0xe2)[0x2ade921a8c12]
/usr/local/cuda/open64/lib//be[0x6d546c]
/usr/local/cuda/open64/lib//be[0x6d5a1c]
/usr/local/cuda/open64/lib//be[0x54012d]
/usr/local/cuda/open64/lib//be[0x54142c]
/usr/local/cuda/open64/lib//be[0x571064]
/usr/local/cuda/open64/lib//be[0x571c15]
/usr/local/cuda/open64/lib//be[0x57251e]
/usr/local/cuda/open64/lib//be[0x57163f]
/usr/local/cuda/open64/lib//be[0x572ff1]
/usr/local/cuda/open64/lib//be[0x5720f2]
/usr/local/cuda/open64/lib//be[0x57679b]
/usr/local/cuda/open64/lib//be[0x5772c9]
/usr/local/cuda/open64/lib//be[0x5779ac]
/usr/local/cuda/open64/lib//be[0x553392]
/usr/local/cuda/open64/lib//be[0x405443]
/usr/local/cuda/open64/lib//be[0x4061f1]
/usr/local/cuda/open64/lib//be[0x40752d]
/lib/libc.so.6(__libc_start_main+0xfd)[0x2ade9218eabd]
/usr/local/cuda/open64/lib//be[0x4038da]
======= Memory map: ========
00400000-0084b000 r-xp 00000000 08:06 1715807 /usr/local/cuda/open64/lib/be
0094a000-0096e000 rw-p 0044a000 08:06 1715807 /usr/local/cuda/open64/lib/be
0096e000-00ecb000 rw-p 00000000 00:00 0
00f93000-02385000 rw-p 00000000 00:00 0 [heap]
2ade917a4000-2ade917c3000 r-xp 00000000 08:06 2405 /lib/ld-2.10.1.so
2ade917c3000-2ade917c6000 rw-p 00000000 00:00 0
2ade919c2000-2ade919c3000 r--p 0001e000 08:06 2405 /lib/ld-2.10.1.so
2ade919c3000-2ade919c4000 rw-p 0001f000 08:06 2405 /lib/ld-2.10.1.so
2ade919c4000-2ade91ab6000 r-xp 00000000 08:06 6145 /usr/lib/libstdc++.so.6.0.13
2ade91ab6000-2ade91cb6000 ---p 000f2000 08:06 6145 /usr/lib/libstdc++.so.6.0.13
2ade91cb6000-2ade91cbd000 r--p 000f2000 08:06 6145 /usr/lib/libstdc++.so.6.0.13
2ade91cbd000-2ade91cbf000 rw-p 000f9000 08:06 6145 /usr/lib/libstdc++.so.6.0.13
2ade91cbf000-2ade91cd4000 rw-p 00000000 00:00 0
2ade91cd4000-2ade91d56000 r-xp 00000000 08:06 2416 /lib/libm-2.10.1.so
2ade91d56000-2ade91f56000 ---p 00082000 08:06 2416 /lib/libm-2.10.1.so
2ade91f56000-2ade91f57000 r--p 00082000 08:06 2416 /lib/libm-2.10.1.so
2ade91f57000-2ade91f58000 rw-p 00083000 08:06 2416 /lib/libm-2.10.1.so
2ade91f58000-2ade91f6e000 r-xp 00000000 08:06 1334 /lib/libgcc_s.so.1
2ade91f6e000-2ade9216d000 ---p 00016000 08:06 1334 /lib/libgcc_s.so.1
2ade9216d000-2ade9216e000 r--p 00015000 08:06 1334 /lib/libgcc_s.so.1
2ade9216e000-2ade9216f000 rw-p 00016000 08:06 1334 /lib/libgcc_s.so.1
2ade9216f000-2ade92170000 rw-p 00000000 00:00 0
2ade92170000-2ade922d6000 r-xp 00000000 08:06 2410 /lib/libc-2.10.1.so
2ade922d6000-2ade924d6000 ---p 00166000 08:06 2410 /lib/libc-2.10.1.so
2ade924d6000-2ade924da000 r--p 00166000 08:06 2410 /lib/libc-2.10.1.so
2ade924da000-2ade924db000 rw-p 0016a000 08:06 2410 /lib/libc-2.10.1.so
2ade924db000-2ade924e2000 rw-p 00000000 00:00 0
2ade92b79000-2ade92b7a000 rw-p 00000000 00:00 0
2ade92b7a000-2ade92c1c000 rw-p 00000000 00:00 0
2ade92c1c000-2ade938db000 rw-p 00000000 00:00 0
2ade938db000-2ade938dc000 rw-p 00000000 00:00 0
2ade94000000-2ade94021000 rw-p 00000000 00:00 0
2ade94021000-2ade98000000 ---p 00000000 00:00 0
7fffc98f4000-7fffc9909000 rw-p 00000000 00:00 0 [stack]
7fffc9984000-7fffc9985000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
Signal: Aborted in Code_Expansion phase.
<input>(0): Error: Signal Aborted in phase Code_Expansion -- processing aborted
*** Internal stack backtrace:
/usr/local/cuda/open64/lib//be [0x6d47bf]
/usr/local/cuda/open64/lib//be [0x6d5409]
/usr/local/cuda/open64/lib//be [0x6d4b5d]
/usr/local/cuda/open64/lib//be [0x6d5da6]
/lib/libc.so.6 [0x2ade921a3530]
/lib/libc.so.6(gsignal+0x35) [0x2ade921a34b5]
/lib/libc.so.6(abort+0x180) [0x2ade921a6f50]
/lib/libc.so.6 [0x2ade921dc1b7]
/lib/libc.so.6 [0x2ade921e62f6]
/lib/libc.so.6(cfree+0x6c) [0x2ade921eac6c]
/usr/local/cuda/open64/lib//be [0x5e3ef5]
/lib/libc.so.6(exit+0xe2) [0x2ade921a8c12]
/usr/local/cuda/open64/lib//be [0x6d546c]
/usr/local/cuda/open64/lib//be [0x6d5a1c]
/usr/local/cuda/open64/lib//be [0x54012d]
/usr/local/cuda/open64/lib//be [0x54142c]
/usr/local/cuda/open64/lib//be [0x571064]
/usr/local/cuda/open64/lib//be [0x571c15]
/usr/local/cuda/open64/lib//be [0x57251e]
/usr/local/cuda/open64/lib//be [0x57163f]
/usr/local/cuda/open64/lib//be [0x572ff1]
/usr/local/cuda/open64/lib//be [0x5720f2]
/usr/local/cuda/open64/lib//be [0x57679b]
/usr/local/cuda/open64/lib//be [0x5772c9]
/usr/local/cuda/open64/lib//be [0x5779ac]
/usr/local/cuda/open64/lib//be [0x553392]
/usr/local/cuda/open64/lib//be [0x405443]
/usr/local/cuda/open64/lib//be [0x4061f1]
/usr/local/cuda/open64/lib//be [0x40752d]
nvopencc INTERNAL ERROR: /usr/local/cuda/open64/lib//be died due to signal 4
CMake Error at CMakeFiles/potts_generated_potts.cu.o.cmake:258 (message):
Error generating file /home/john/projects/CPM/./potts_generated_potts.cu.o
