Is it feasible to install both CUDA3.2 and CUDA4.0 on one linux distribution?
Driver,cudatoolkit and cudasdk are re-packaged as rpm format. That means they are ordered by dependency.
I’d like to install them in the specified directory and use the two versions when necessary.
e.g.
/usr/local/project/nvidia/3.2
/usr/local/project/nvidia/4.0
my shell script:
#!bin/bash
echo “Install NVIDIA_CUDA_3.2”
rpm -ivh nvidia-260.19.21-x86_64.rpm
rpm -ivh cudatoolkit-3.2.16-x86_64.rpm
rpm -ivh cudasdk-3.2.16-x86_64.rpm
ln /lib/modules/uname -r
/kernel/drivers/video/nvidia.ko /usr/local/project/nvidia/3.2/260.19.21
rpm -e nvidia-260.19.21 //in order to install another driver
echo “Install NVIDIA_CUDA_4.0”
rpm -ivh nvidia-270.27-sgi.cl55.1.1.x86_64.rpm
rpm -ivh cudatoolkit-4.0.11-sgi.cl55.1.1.x86_64.rpm
rpm -ivh cudasdk-4.0.11-sgi.cl55.1.1.x86_64.rpm
/kernel/drivers/video/nvidia.ko /usr/local/project/nvidia/4.0/270.27
Then if I want to use CUDA3.2, I will do:
export PATH=/usr/local/project/nvidia/3.2/cuda/bin
export LD_LIBRARY_PATH=/usr/local/project/nvidia/3.2/cuda/lib64
export CUDA_INSTALL_PATH=/usr/local/project/nvidia/3.2/cuda
rmmod nvidia
insmod /usr/local/project/nvidia/3.2/260.19.21
If i want to use CUDA 4.0,I would do:
export PATH=$PATH:/usr/local/project/nvidia/4.0/cuda/bin
export LD_LIBRARY_PATH=/usr/local/project/nvidia/4.0/cuda/lib64
export CUDA_INSTALL_PATH=/usr/local/project/nvidia/4.0/cuda
rmmod nvidia
insmod /usr/local/AEE/nvidia/4.0.11/270.27
However, I encounter a critical problem which will prompt me driver component version and module version mismatch and fail to run cuda sample.
So what shall I do to make two versions co-exist?
Thank you in advance!
