I am currently using CUDA 3.2 and would like to try out CUDA 4.0. Do I simply install CUDA 4.0 over 3.2? Will I need to remove anything, e.g. drivers etc?
Thank you.
Regards,
Rayne
Thank you.
Regards,
Rayne
You must update the driver, that can safely be installed over the top of the old driver. I find it good practice to keep a copy of the installer for the driver I am about to replace somewhere easy to find in case things don’t work and I need to roll back. For toolkits, I would recommend installing the 4.0rc kit in an alternative path and having both. You only need to change path settings to switch back and forth: CUDA 3.2 runs fine with the newer driver, and if you find a bug, you can just switch back to 3.2. I keep a lot of toolkits installed at the same time for testing purposes, something like Modules is an excellent tool for managing this sort of thing.
Which path settings should I change? nvcc? Directories of where the header files, e.g. cuda.h are stored? Any others?
At the bare minimum
[*]LD_LIBRARY_PATH to point to the correct path containing the CUDA runtime libraries (so installpath/lib or installpath/lib64)
[*]PATH to point to the correct path holding nvcc and the other executables from the toolkit (so installpath/bin)
If you have makefiles, then you probably also need to change the “prefix path” in those.
I find it good practice to define a top level environment variable which leads to the install path of the CUDA version I am using, and then just have makefiles use that.
The equivalent module file for CUDA 3.2 on our cluster looks like this:
#%Module1.0
## cuda modulefile
module-whatis "Loads the CUDA 3.2 gpu computing environment"
set cuda_root /export/opt/cuda-3.2
setenv CUDA_INSTALL_PATH $cuda_root
setenv CUBLAS_INSTALL_PATH $cuda_root
setenv CUBLAS_LIBRARIES "-L$cuda_root/lib64 -lcublas -lcudart"
setenv CUBLAS_INCLUDES -I$cuda_root/include
append-path PATH $cuda_root/bin:$cuda_root/cudaprof/bin
append-path LD_LIBRARY_PATH $cuda_root/lib64:$cuda_root/cudaprof/bin
that defines everything our standard makefiles, job scripts, etc need to build and run against the 3.2 toolkit.
