I am totally newbie in CUDA programming. I have a very simple and basic question.
I want to make 32bit and 64bit application in my Windows 7 32bit laptop.
Is it possible with CUDA 6.5? I have read getting started document and I am not sure about it.
Is the following procedure right? I work in VS2010 environment.
(1) I downloaded CUDA toolkit 6.5 from https://developer.nvidia.com/cuda-downloads.
I chose the link, ‘Windows 7 Desktop 32bit EXE’ in the table.
(2) I installed it on my laptop. Then, it is installed in
‘C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5’ folder
(3) T have already a *.cu file in my project.
(4) I used the compiler CUDA\v6.5\bin\nvcc.exe and give the compile option ‘-m 32’
to build 32bit application and ‘-m 64’ to build 64bit application.
(5) I used lib files under CUDA\v6.5\lib\Win32 as addlitional dependencies in VS2010 project setting
to build both 32bit application and 64bit application. (I am not sure if this is correct or not).
Thanks in advance for your answers.
