Hello everyone.
For some time now I’ve been experimenting with cuda. So I had wrote some myVector/myMatrix/myTensor structs for my experiments. But I thought to pass it on to C++ classes. Well I had some time to program on C++, so it took me a day to resolve my compilation errors.
Now I try to create a test_kernel and call it through myVector class. But I can’t resolve these compilation errors. So If you could give a hint, would be much appreciated.
Here is my code ::
cudalaLIB++.cuh
#include "laLIB++.h"
#include <cuda.h>
#include <cutil_inline.h>
extern "C" void trialKernel(float* array, int elements);
template <class T>
class cuVector : public iVector<T>
public:
cuVector() :
iVector<T>()
cout << "A cuVector was created." << endl;
cuVector(int _nElements) :
iVector<T>(_nElements),
size(_nElements*sizeof(T))
cout << "cuVector consc2." << endl;
cuVector(int _nElements, T _element) :
iVector<T>(_nElements, _element)
cout << "cuVector consc3." << endl;
void allocVectorOnDev()
cudaMalloc((void **) &this->deviceCopyOfElements, this->size); // Allocate array on device
void copyVectorOnDev()
cudaMemcpy(this->deviceCopyOfElements, this->elements, size, cudaMemcpyHostToDevice);
void allocAndCopyVectorOnDev()
allocVectorOnDev();
copyVectorOnDev();
void copyVectorBackOnHost()
cudaMemcpy(this->elements, this->deviceCopyOfElements, size, cudaMemcpyDeviceToHost); // Copy memory on device.
T* getDCOE()
return this->deviceCopyOfElements;
void callTrialKernel()
trialKernel((float*) this->deviceCopyOfElements, this->nElements);
private:
size_t size;
T* deviceCopyOfElements;
cudalaLIB++.cu
#include "cudalaLIB++.cuh"
__global__ void trial_kernel(float* array)
int x = threadIdx.x;
array[x] = 0;
dim3 grid(elements);
dim3 block(elements);
trial_kernel<<<grid, block>>>(array);
main.cpp
#include <iostream>
using namespace std;
int main(int argc, char** argv)
cout << "Hello World!" << endl;
cuVector<float> vec1(10, .3);
vec1.print();
vec1.allocAndCopyVectorOnDev();
vec1.callTrialKernel();
vec1.copyVectorBackOnHost();
vec1.print();
return 0;
So when I try to compile it I get ::
obj/x86_64/release/myCUDAlaLIB.cpp.o: In function `main':
main.cpp:(.text+0x416): undefined reference to `trialKernel'
If you have any idea how to solve this, would be really helpfull !!
