I have an array and i want to retrieve its minimum element.
The array is filled inside a kernel module, and it all works fine. Then, outside this kernel module, i use the cublasIsamin function to get the index of the minimum element; then i call another kernel module to do some more computations.
The problem is that the cublas function is quite slow (the array has about 10 000 elements) and before i execute the second kernel module, precisely at the instruction
CUT_DEVICE_INIT();
i have a runtime error.
If i don’t execute the cublas function i don’t have the same error any more.
What could generate this error? Maybe there is no more place in the memory?
i tought i had to reinitialise it everytime…
but apparently the problem is not this. I still have a run time error at the next CUDA function (CUDA_SAFE_CALL(cudaFree(…)) or CUDA_SAFE_CALL(cudaMalloc(…))) i execute after the cublasIsamin()…
Hmm that is odd. I’ve never used cublas, but if I had to guess from the information you’ve given, maybe your call to cublasIsamin() is causing the problem (i.e. writing outside of a memory array or something). Have you double checked the values of all arguments being passed to the cublas function? Could you post a short code example that demonstrates the problem (preferably an example that can copied and pasted and then compiled with nvcc -o file file.cu).
my project is quite big and i’m using the Visual Studio 2005 environment so i tested a very simple code and i obtain the same problems (It’s not so clear to me how to write some code executable with ncvv… cut i think the code i’m posting here should be simply to test.).
The odd tiings i noticed are:
1. The cublasIsamin(..) function takes a considerable amount of time to do its job (here the vector has only 10 elements but it's the same for a vector of 100 or 100 elements)
2. The cublasIsamin(..) always returns the 0 index, so it apparently does not work.
3. No matter which CUDA instruction we use after it, we have a run time error
