I suspect that my CUDA Toolkit (version 3) is not supported by my runtime?
So how do I upgrade the runtime? or Downgrade the toolkit?
My device driver could be upgraded if I use the very latest, and not the latest supplied by HP my OEM, not sure if I should go down this route.
I was trying to run the GPU examples, but then realised my card is a FX2700M and the samples html suggests I need at least a quadro 4800.
Given the sample isn’t doing anything much why does it need a more powerful device?
Can I re-write the code to avoid the necessity of having a 4800?
This tells you to intall the developer driver, toolkit and sdk in that order.
I didn’t install the developer driver.
Actually it doesn’t seem to matter what order as far as I can tell as it now seems to work now I have installed the driver.
Not sure what the CUDA sdk is as there isn’t one as far as I can tell. There is a GPU sdk amongst other downloads and I presume this is what they mean.
