Having a .h, I want to define real to be double if compiling for c/c++ or for cuda with computing capability >= 1.3. If compiling for cuda with computing capability < 1.3 then define real to be float.
I tried:
# if defined(__CUDACC__)
# warning * making definitions for cuda
# if defined(__CUDA_ARCH__)
# warning __CUDA_ARCH__ is defined
# else
# warning __CUDA_ARCH__ is NOT defined
# endif
# if (__CUDA_ARCH__ >= 130)
# define real double
# warning using double in cuda
# elif (__CUDA_ARCH__ >= 0)
# define real float
# warning using float in cuda
# warning how the hell is this printed when __CUDA_ARCH__ is not defined?
# else
# define real
# error what the hell is the value of __CUDA_ARCH__ and how can I print it
# endif
# else
# warning * making definitions for c/c++
# warning using double for c/c++
# endif
and compiled
nvcc -arch compute_13 -Ilibcutil testFloatDouble.cu
but it doesn’t work since in the second compilation pass, CUDACC is defined
but CUDA_ARCH seems not to:
how the hell is this printed if __CUDA_ARCH__ is not defined now?
Undefined symbols for architecture i386:
"myKernel(float*, int)", referenced from: ....
Any help is welcome. Thanks
