I have had some issues with the lack of precision when using floats so I decided to try it out with doubles instead. I have another system coded in java in which I confirm that cuda calculated “correct”. I only verify that on a fraction of the material that goes throught the gpu. The java program and cuda usually comes to the same result. However because the java program uses doubles and the cudaprogram uses floats sometimes there can be differences due to precision issues. ( for other reasons I need to use doubles on the java-part)
So I ran a test with floats as usual and printed the output (which is like 500000 rows so quite much ) then I upgraded to doubles in the cudacode and ran the exact same test. To my surprise I got the exact same result with doubles as with floats. This led me to believe that I have some issue with the compilation. I’m quite sure that doubles can be converted to floats even if you have written double in the code if you compile with some compliler-flag or similar. My compilation lines of interest looks like this:
I have different cards available here if that matters. The card I tested it on now was a GTX 260. But I also got a GTX480. Is it better to compile with some other settings on the GTX480 in general by the way?
Im running linux and on the machine with the GTX260 I have CUDA Driver and Runtime version 3.0 and nvidia-drivers version 195.36.31 if that is important as well.
Anyone have any clue what might be the problem here?
I was using the computer to other things as well during the runs so maybe the difference would be smaller otherwise too. Expected it to be more difference.
Not sure about the gencode-part? Can I just add that as a compile-parameter?
I found some info in a guide called “Fermi_Compatibility_Guide” where it said the following:
Note: the nvcc command-line option “-arch=sm_xx†is a shorthand equivalent
to the following more explicit –gencode command-line options.
–gencode=arch=compute_xx,code=sm_xx
–gencode=arch=compute_xx,code=compute_x
So it seems that -arch=sm_13 should be enough, if I dont misunderstand something here. But it seems that is not because I get the exact same output still =( . I assume the name for double in cuda is ‘double’ and not something else like float64 or something fishy?
I’m trying without success to use other compiler parameters. Could you give a line for me how you would write it with -gencode or -code please, Im stuck here.
Another question, is there some way that I can see what “version” the compiled code has or similar so I can be sure what version that it is that is actually being executed?
I think I found my problem. Before I when I used floats I wanted to use IEEE-compliant float operations so I used __fdiv_rn for division and similar for +,-,. I forgot to change those when I changed to doubles. And because those are float-operations some conversions to floats may have happened there. It seems to work now when I changed to “ordinary” +,-,,/ =)
I have a followup-question thou, are there similar functions availables for double like __fdiv_rn for floats? Or are the standard operations when working with doubles IEEE-compliant so to speak ( +,-,*,/ ). I remember when I used floats and was not using __fdiv_rn a number divided by itself was not guarenteed to be 1 for example which leads to problem for my application.
Basic arithmetic operations (+,-,*,/,sqrt) on double-precision operands always use IEEE round-to-nearest-or-even. There are also device functions that allow to select the rounding mode:
Ah ok thanks! I will look closer on them. I guess the __dX_rn for double is what will work best for me as well then ( because I used the __fdiv_rn for floats). Unless the ‘n’ already is the “round-to-nearest-or-even”, I can’t remember right now, getting late here =)
