I have just installed Ubuntu 22.04. My Nvidia card is a Geforce GT 710. Nvidia libaries installed fine.
nvidia-smi output is
| NVIDIA-SMI 470.182.03 Driver Version: 470.182.03 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 N/A | N/A |
| 50% 47C P0 N/A / N/A | 234MiB / 2000MiB | N/A Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Its working fine.
On Ubuntu 20 I had the CUDA libraries (toolkit 11) installed and was able to compile tensorflow using docker.
I wish to do the same for 22.04. However when installing cuda using apt-get install cuda it wants to uninstall the 470 drivers for my card and install the 530 drivers and toolkit 12. So,
- Is this correct?
- Will my card still work?
- Is toolkit 12 suitable?
I have noted that there is a version of cudnn for toolkit 11 and downloaded, but not installed, the link
cudnn-local-repo-ubuntu2204-8.9.2.26_1.0-1_amd64.deb. If this is available, why can’t I find the link to the 11.x
Thanks for your help
