CUDA and OpenGL
I am trying to get CUDA to accept my OpenGL Renderbuffer Object, but I always get an invalid argument error.
I have this rather simple code.
[codebox]
// do basic initialization
glGenFramebuffers(1, &frameBuffer);
glGenRenderbuffers(1, &depthBuffer);
glBindFramebuffer(GL_FRAMEBUFFER, frameBuffer);
glBindRenderbuffer(GL_RENDERBUFFER, depthBuffer);
glRenderbufferStorage(GL_RENDERBUFFER, GL_DEPTH_COMPONENT, windowWidth, windowHeight);
glBindRenderbuffer(GL_RENDERBUFFER, 0);
glFramebufferRenderbuffer(GL_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_RENDERBUFFER, depthBuffer);
glBindFramebuffer(GL_FRAMEBUFFER, 0);
// … do some additional initialization
cudaGLSetGLDevice(0);
cudaGraphicsGLRegisterImage(&cudaDepthMap, depthBuffer, GL_RENDERBUFFER, cudaGraphicsMapFlagsNone);[/codebox]
I have a valid CUDA Device, I have a valid renderbuffer and a complete framebuffer object.
I have tried searching the web, but I did not find an answer, that solves my problem.
Thank you in advance,
Markus
[codebox]
Markus
Same problem. But in my case I’m trying to register a color buffer.
If anyone figure out with cudaGraphicsGLRegisterImage returns invalid resource handle please let us know.
From my memory, but I am quite sure you can find it in the doc.
The opengl interoperability does not work for every buffer formats, and it was not working with GL_DEPTH_COMPONENT, at least in cuda 3
I agree, it is quite boring…
I use a texture instead of a render buffer object and works fine. Even the documentation saying that one can map render buffer objects, it keeps saying that it is a invalid resource.
BTW, I’m trying to register a render buffer as a color buffer, not depth.
