Hi!
I wanted to try some CUDA enabled applications and discovered that there must be something wrong with the current driver (or my Quadro FX 570 is damn slow…).
My configuration:
Vista Business SP1, 32-bit
3GB RAM
Intel Core2Duo Quad 2.4GHz
Quadro FX 570 with 256MB RAM on PCI Express x16
Quadro driver 182.08
To start testing CUDA I’ve tried to run the bandwidthTest from the CUDA-SDK. The output is:
Host to Device Bandwidth for Pageable memory
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 1523.5
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 1317.3
Quick Mode
Device to Device Bandwidth
33554432 5923.8
Don’t know if those values are withing range but as a second test, I tried the BarsWF MD5 bruteforcer (0.8 CUDA) and the results are quite disappointing: My CPU computes about 150 million hashes per second while the GPU only reaches 25 million hashes. I expected the GPU to be several times faster than the CPU!
Other CUDA apps I’ve tried also perform unexpectedly slow (ElcomSoft’s Password Recovery Agent for example)…
Am I doing something wrong here?
