I tried nvcr.io/nvidia/tensorflow to run tensorflow examples on GPU with multiple tags.
With recent on (19.01-py3), it said ERROR: Detected NVIDIA Tesla K80 GPU, which is not supported by this container.
Then, I tried old versions 18.11, 18.10, and 18.05 since they used old version of tensorflow (1.11) since the TF requires lower GPU compute capabilities.
However, it still showed the same messages when I started a docker.
And when I run label_image.py example, it showed this message.
I tensorflow/core/common_runtime/gpu/gpu_device.cc:1394] Ignoring visible gpu device (device: 2, name: Tesla K80, pci bus id: 0000:86:00.0, compute capability: 3.7) with Cuda compute capability 3.7. The minimum required Cuda capability is 5.2.
This is output from nvidia-smi.
| NVIDIA-SMI 410.48 Driver Version: 410.48 |
| 0 Tesla K80 Off | 00000000:04:00.0 Off | Off |
| N/A 66C P0 61W / 149W | 0MiB / 12206MiB | 0% Default |
| 1 Tesla K80 Off | 00000000:05:00.0 Off | Off |
| N/A 44C P0 74W / 149W | 0MiB / 12206MiB | 0% Default |
| 2 Tesla K80 Off | 00000000:86:00.0 Off | Off |
| N/A 36C P0 60W / 149W | 0MiB / 12206MiB | 0% Default |
| 3 Tesla K80 Off | 00000000:87:00.0 Off | Off |
| N/A 51C P0 72W / 149W | 0MiB / 12206MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
With Tesla K80, is there any way of using tensorflow in docker images (TensorFlow | NVIDIA NGC)?
Thanks,
