Hi There.
I am trully tired of testing hundreds of applications, supporting CUDA … Every of them crashes after short while (or immediatelly sometimes). I have pure installation on my PC, with all latest and stabile drivers. Good pc case cooling. There's any single problem at all, only CUDA makes me sad. I am working every day with video from my 5D MARK II (I am a photographer/videographer) and I need CUDA supported converting. I was 'googling' everywhere, testing tons of drivers, utilities, soft … nothing was helping for me. (and I am not alone, as I see on other sites)
Is there ANYONE, who solved this problem? PLEEEASE ! :-*
(GIGABYTE P55A UD6, 16GB ram, i7 870s, MSI N460GTX Cyclone 768D5/OC, PCI-E, OCZ REVODRIVE 180GB, SW raid 2x WD Caviar Blue KS - 640GB)
please, if you have the same problem, or you know how to fix this, add me on facebook under Petr Fink, or skype fink.cz
Hi There.
When you say crash, does it give you a segmentation error or is it your display driver that crashes?
If it is segmentation, I have no idea what is wrong. If it is the other, try and look at the max delay you are allowing the kernels to run for. Take a look at
[url=“http://wiki.accelereyes.com/wiki/index.php/FAQ#What_is_Timeout_Detection_and_Recovery_and_why_should_I_care.3F”]http://wiki.accelereyes.com/wiki/index.php...hould_I_care.3F[/url]
for further explanation.
hi there again … it seems that bios update on Gigabyte MOBO has solved the problem. It seems that freezing and crashing in major CUDA video converters I am using has vanished. Have a verrrryyy nice day and thank you for friendly support.
Petr.
Petr.
