Hi All,
After installing Parallel Nsight 2.1 (for Cuda 4.1 RC2 version), I get Connected and Disconnected pop up, immediately. I have done the general settings for running NSight on my Visual studio 2010. I wish to debug on localhost itself.
I have a few questions:
- I have read through sections of the Parallel NSight user manual, It didn’t help too much for this issue.
- Can I start local debugging directly with NSight-> Start Cuda Debugging for starting to debug my project OR should I click on this option only (& everytime) I step into the kernel ?
- The other way I tried is, I started with normal CPU debugging, just when I hit the kernel, selected step 2) and got the following (screenshot): (This time it said ‘Connected to Cuda Debugger’):
[Cuda_Debug_CPUDebug_to_NSight.jpg]
And as soon I pressed (F10, default) for debugging it said “Debugger cannot run Cuda kernel”.
(Debugger_Cannot_Run_Cuda.jpg)[b]
Has anyone else faced this problem ?
Could you please let me know the procedure for cuda kernel invocation. I just want to debug the kernel. Where am I going wrong ?
Best Regards,
[/b]Shyam B
