CUDA device not found while using blackwell
In my current setup I have a NVIDIA RTX PRO 6000 Blackwell, here is the output of nvidia-smi
| NVIDIA-SMI 580.126.09 Driver Version: 580.126.09 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX PRO 6000 Blac… Off | 00000000:15:00.0 Off | 0 |
| N/A 32C P8 33W / 600W | 0MiB / 97887MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| No running processes found |
I am running ubuntu 22.04, everything seems to be up to the requirements according to the docs, however, when I run a sample application I get cudaErrorInsufficientDriver = 35. I can not figure out what the problem is though I suspect it is a system config issue. Also, I am running the samples inside a docker container, the gpu is mapped correctly to the container.
Thank you for your time in advance,
Francisco
I have found another post in the forum that solves my issue
