Ubuntu no longer sees RTX 3060 after installing CUDA
I have been trying to install CUDA toolkit 11.1.1 on my Ubuntu so I can then use the LTS PyTorch 1.8.2.
Following are the hardward and software specifications of my system:
Motherboard: ASUS TUF GAMING X570-PLUS (WI-FI) Rev X.0x
CPU: AMD Ryzen 7 5800X 8-Core Processor
GPU: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
OS: x86_64 Ubuntu 20.04.1 LTS (Focal Fossa)
Driver: nvidia-driver-470 (proprietary) v470.103.01
Kernel: 5.4.0-42-generic, GCC: 9.3.0, GLIBC: 2.31
I believe the specs have met all the requirements listed in installation guide and release notes
So I followed through with the download instructions and successfully installed cuda.
Upon restart, as soon as launching into Ubuntu, the monitor, which is directly hdmi-ed into the 3060, black screened, with no more display coming through. After relaunching into Ubuntu but in recovery mode this time, ā€œnvidia-smiā€ in the root bash wielded ā€œno devices were foundā€ and ā€œnvcc -Vā€ wielded cuda not installed and suggested a sudo apt install of cuda 10.1, which I believe is not compatible with Ubuntu 20.04.
I have now reinstalled Ubuntu, and without installing cuda, ā€œnvidia-smiā€ is able to see gpu and works just fine.
How do I correctly install cuda without running into previous issues?
notes:
*secure boot is turned off in the system bios
*there is a fresh Windows dual booted on my device
Please help to attach nvidia bug report from repro state.
Hi amrits,
I’m sorry, but there was not really any error or warning logs during any stage.
All went smoothly until blank-screen during ubuntu restart, where the only log in recovery mode was device not found and cuda not installed.
Is there any command I could enter to debug the issue further or trigger some internal log?
thanks
The full cuda package also installs an (incompatible) driver. Just install cuda-toolkit to avoid that
sudo apt install cuda-toolkit-11-1
Thank you sir!
That correctly solved my problem!
