CUDA Driver API location & Toolkit extraction failed
I’m using a tool which have to load (dlopen) the Cuda Driver API to call its functions. The problem is that I can’t locate where is the library with symbols of this API. I tried the libcuda.so, but the nm command returns a limited list of symbol (00a204fc b cudbgIpcFlag & 00a20500 b cudbgRpcEnabled - functions are not there) and the library can’t be opened in the tool (Error loading /usr/lib64/libcuda.so: HandlerInit function not found.)
I read something about the CUDA toolkit, but I can’t extract it (Extraction failed. Signal caught, cleaning up).
Does someone please know where is the library containing symbols of functions of the CUDA Driver API ?
Best regards
EDIT : I succeeded installing the toolkit, but still no Driver API :s
EDIT 2 : that’s ok, I finally found that I was misinterpreting the code of the tool. Functions are in libcuda.so ;-)
