I use PyTorch NGC Container 23.05-py3. And use `nvidia-docker run -it --rm -v nvcr.io/nvidia/pytorch:23.05-py3 to launch it. It show that
ERROR: The NVIDIA Driver is present, but CUDA failed to initialize. GPU functionality will not be available.
[[ Initialization error (error 3) ]]
I run nvidia-smi
,it output
Wed Jun 7 12:17:34 2023
| NVIDIA-SMI 530.41.03 Driver Version: 530.41.03 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA A100-SXM4-80GB Off| 00000000:40:00.0 Off | On |
| N/A 27C P0 31W / 400W| 0MiB / 81920MiB | N/A Default |
| | | Enabled |
| 1 NVIDIA A100-SXM4-80GB Off| 00000000:B1:00.0 Off | On |
| N/A 26C P0 36W / 400W| 0MiB / 81920MiB | N/A Default |
| | | Enabled |
| MIG devices: |
| GPU GI CI MIG | Memory-Usage | Vol| Shared |
| ID ID Dev | BAR1-Usage | SM Unc| CE ENC DEC OFA JPG|
| | | ECC| |
| No MIG devices found |
| Processes: |
| ID ID Usage |
| No running processes found |
I run nvcc --version
,it show
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Mon_Apr__3_17:16:06_PDT_2023
Cuda compilation tools, release 12.1, V12.1.105
Build cuda_12.1.r12.1/compiler.32688072_0
Besides, I run this contain in a lxc contain.
