when i deploy the NGC pytorch container in docker, a warnning occurs"WARNING: The NVIDIA Driver was not detected. GPU functionality will not be available. Use ‘nvidia-docker run’ to start this container; ", after that I run the cmd to check whether is cuda is available in pytorch workspace, the result is True.
root@31fdd296e497:/workspace# import torch
bash: import: command not found
root@31fdd296e497:/workspace# python
Python 3.6.10 |Anaconda, Inc.| (default, May 8 2020, 02:54:21)
[GCC 7.3.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import torch
print(torch.cuda.is_available())
True
Why the warnning occurs?
- my environment info:
OS: win11+wsl2+ubuntu20.04;
GPU : RTX3080;
- nvidia-smi info:
| NVIDIA-SMI 470.75 Driver Version: 472.19 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 On | N/A |
| N/A 36C P8 20W / N/A | 1495MiB / 16384MiB | ERR! Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
