Hello All,
I am running below docker command and i am seeing error…
# docker run --privileged --rm --gpus all --ipc=host --ulimit memlock=-1:-1 nvcr.io/nvidia/hpc-benchmarks:23.10 mpirun -np 8 --bind-to none /workspace/hpl-linux-x86_64/hpl.sh --dat /workspace/hpl-linux-x86_64/sample-dat/HPL-8GPUs.dat
================= NVIDIA HPC Benchmarks =================
NVIDIA Release 23.10
Copyright (c) 2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
ERROR: The NVIDIA Driver is present, but CUDA failed to initialize. GPU functionality will not be available.
[[ System not yet initialized (error 802) ]]
I dont’ see any problem while running nvidia-smi inside the container…
# docker run --rm --gpus all nvcr.io/nvidia/cuda:12.2.2-base-ubuntu22.04 bash -c "nvidia-smi" Wed Feb 19 14:20:10 2025
| NVIDIA-SMI 565.57.01 Driver Version: 565.57.01 CUDA Version: 12.7 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA H100 80GB HBM3 On | 00000000:0A:00.0 Off | 0 |
| N/A 30C P0 68W / 700W | 1MiB / 81559MiB | 0% Default |
| | | Disabled |
| 1 NVIDIA H100 80GB HBM3 On | 00000000:18:00.0 Off | 0 |
| N/A 31C P0 70W / 700W | 1MiB / 81559MiB | 0% Default |
| | | Disabled |
| 2 NVIDIA H100 80GB HBM3 On | 00000000:3B:00.0 Off | 0 |
| N/A 32C P0 70W / 700W | 1MiB / 81559MiB | 0% Default |
| | | Disabled |
| 3 NVIDIA H100 80GB HBM3 On | 00000000:44:00.0 Off | 0 |
| | | Disabled |
| 4 NVIDIA H100 80GB HBM3 On | 00000000:87:00.0 Off | 0 |
| N/A 31C P0 69W / 700W | 1MiB / 81559MiB | 0% Default |
| | | Disabled |
| 5 NVIDIA H100 80GB HBM3 On | 00000000:90:00.0 Off | 0 |
| N/A 30C P0 70W / 700W | 1MiB / 81559MiB | 0% Default |
| | | Disabled |
| 6 NVIDIA H100 80GB HBM3 On | 00000000:B8:00.0 Off | 0 |
| | | Disabled |
| 7 NVIDIA H100 80GB HBM3 On | 00000000:C1:00.0 Off | 0 |
| N/A 31C P0 71W / 700W | 1MiB / 81559MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| No running processes found |
More information…
# nvidia-container-cli --version
cli-version: 1.17.4
lib-version: 1.17.4
build date: 2025-01-23T10:53+00:00
build revision: f23e5e55ea27b3680aef363436d4bcf7659e0bfc
build compiler: x86_64-linux-gnu-gcc-7 7.5.0
build platform: x86_64
build flags: -D_GNU_SOURCE -D_FORTIFY_SOURCE=2 -DNDEBUG -std=gnu11 -O2 -g -fdata-sections -ffunction-sections -fplan9-extensions -fstack-protector -fno-strict-aliasing -fvisibility=hidden -Wall -Wextra -Wcast-align -Wpointer-arith -Wmissing-prototypes -Wnonnull -Wwrite-strings -Wlogical-op -Wformat=2 -Wmissing-format-attribute -Winit-self -Wshadow -Wstrict-prototypes -Wunreachable-code -Wconversion -Wsign-conversion -Wno-unknown-warning-option -Wno-format-extra-args -Wno-gnu-alignof-expression -Wl,-zrelro -Wl,-znow -Wl,-zdefs -Wl,--gc-sections
cuda-toolkit version
# nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:33:58_PDT_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
Please let me know where am i doing wrong… ?
