I’m sorry if there is another post with this same content, but I’m trying to solve this problem and I didn’t find a solution yet.
When I try to run the sample projects, I receive this Error 35: Cuda Error Insuficient Driver. I’m using Ubuntu 18.04.2 LTS and a GeForce GT 620.
I will post some information bellow that I found in another posts
nvidia-smi
| NVIDIA-SMI 390.87 Driver Version: 390.87 |
| 0 GeForce GT 620 Off | 00000000:01:00.0 N/A | N/A |
| 52% 49C P12 N/A / N/A | 188MiB / 1984MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
nvcc -V
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Nov__3_21:07:56_CDT_2017
Cuda compilation tools, release 9.1, V9.1.85
ldconfig -p | grep libcuda
libcudart.so.9.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libcudart.so.9.1
libcudart.so (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libcudart.so
libcuda.so.1 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libcuda.so.1
libcuda.so.1 (libc6) => /usr/lib/i386-linux-gnu/libcuda.so.1
libcuda.so (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libcuda.so
libcuda.so (libc6) => /usr/lib/i386-linux-gnu/libcuda.so
njuffa
February 27, 2019, 10:06pm
2
The GeForce GT 620 appears to be a GPU with compute capability 2.1. Recent and current CUDA versions require GPUs with compute capability >= 3.0.
You would want to use a newer GPU, and should be able to find low-cost options among Pascal-family devices such as the GeForce GT 1030 (~ $90), with compute capability 6.x.
The last CUDA version that supported Fermi (cc2.x) devices is CUDA 8.0
Thanks very much for the help
Hi All,
I have the same error but not quite the same environment so I am not sure what the issue is in my case.
When running deviceQuerry from CUDA Samples v10.1 (as well as v10.0) I get:
cudaGetDeviceCount returned 35
→ CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
I am running Windows 10 Pro, 64bit, version 1809
GPU NVS 315, Drivers 392.37 (got it fresh from NVIDIA Driver Downloads)
I got today CUDA Toolkit 10.1 from CUDA Toolkit 11.7 Update 1 Downloads | NVIDIA Developer
and the drivers from Official Drivers | NVIDIA
nvidia-smi gives
| NVIDIA-SMI 392.37 Driver Version: 392.37 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 NVS 315 WDDM | 00000000:01:00.0 N/A | N/A |
| 30% 36C P8 N/A / N/A | 272MiB / 1024MiB | N/A Default |
| 0 Not Supported |
Would anyone know what the issue is here?
Thank you very much for your help
njuffa
March 4, 2019, 6:51pm
6
Posts #2 and #3 apply to the NVS 315, which is a Fermi-architecture GPU from around 2012.
OK, thx njuffa, good to know! Regards
