Cuda error on Jetson
Version info:
Jetson Orin Nano
nvcc
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Thu_Mar_28_02:23:12_PDT_2024
Cuda compilation tools, release 12.4, V12.4.131
Build cuda_12.4.r12.4/compiler.34097967_0
nvidia-smi output
| NVIDIA-SMI 540.2.0                Driver Version: N/A          CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Orin (nvgpu)                  N/A  | N/A              N/A |                  N/A |
| N/A   N/A  N/A               N/A /  N/A | Not Supported        |     N/A          N/A |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
And I am trying to compile a cuda program for cosine similarity kernel. The program launches fine but on running I am getting error,
kernel launch failed: no kernel image is available for execution on the device
The same code is working on dGPU with nvcc version 11.4
Please help regarding
Working now, just install cuda 11.7 on the jetson device with the help of,
cuda-11.7 downloads
