We recently got a Quadro 8000 for training purposes at our lab. However, I am not able to run the simplest of codes, where cuda_driver.cc complains about failing to allocate memory (with subsequent messages indicating that cuda failed to allocate 38.17G, then 34.36G, 30.92G, 27.83G, 25.05G, 22.54G) even when GPU:0 is shown to be having 39090 MB memory. I am using miniconda based python with tensorflow-gpu 2.0.0 and compatible versions of cudnn(7.6.4) and cudatoolkit(10.0.130) pulled automatically using conda install. The simple code is as follows.
from future import absolute_import, division, print_function, unicode_literals
import tensorflow as tf
gpus = tf.config.experimental.list_physical_devices(‘GPU’)
if gpus:
try:
#tf.config.experimental.set_virtual_device_configuration(
#    gpus[0],[tf.config.experimental.VirtualDeviceConfiguration(memory_limit=1024*20)])
#tf.config.experimental.set_memory_growth(gpu, True)
#  print(‘tf Memory growth : %r’ % (tf.config.experimental.get_memory_growth(gpus[0])))
logical_gpus = tf.config.experimental.list_logical_devices('GPU')
print("%d Physical GPUs, %d Logical GPUs" % (len(gpus), len(logical_gpus)))
a = tf.constant([[1.0, 2.0, 3.0], [4.0, 5.0, 6.0]])
b = tf.constant([[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]])
c = tf.matmul(a, b)
print(c)
except RuntimeError as e:
# Memory growth must be set before GPUs have been initialized
print(e)
I do have a temporary fix, by setting a memory limit by uncommenting the first two lines after the try statement in the code above. I discovered though, that I cannot force the gpu to allocate more than approximately 20G, eventhough the gpu has around double the memory available.
Googling around points to setting either the memory growth or memory limit on the GPU. I have even tried to set both (uncommenting the 3rd and 4th lines as well), but to no avail.
Anyone come across a similar issue?
Thanks for reading.
