Blender needs a NVIDIA compute capability of 3.0 at least.
In one system (openSUSE Tumbleweed) with this gfxcard:
Tue Feb 18 20:55:37 2020
| NVIDIA-SMI 440.59 Driver Version: 440.59 CUDA Version: 10.2 |
| 0 GeForce GTX 650 Off | 00000000:01:00.0 N/A | N/A |
| 16% 30C P8 N/A / N/A | 72MiB / 1998MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
Blender 2.82 throws an error:
Read prefs: /home/user/.config/blender/2.82/config/userpref.blend
psutil available
CUDA cuInit: Unknown error
Saved session recovery to '/tmp/quit.blend'
Blender quit
Any idea, how to debug this any further?
Thanks, Robert.
After symlinking gcc-7 and g+±7 to ~/bin/{gcc,g++}, make -k compiled most of the examples, produced 177 items in bin/x86_64/linux/release, but…
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 100
-> no CUDA-capable device is detected
Result = FAIL
kuno:~# lspci -vs 01:00.0
01:00.0 VGA compatible controller: NVIDIA Corporation GK107 [GeForce GTX 650] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device 2263
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at fd000000 (32-bit, non-prefetchable)
Memory at e0000000 (64-bit, prefetchable)
Memory at f0000000 (64-bit, prefetchable)
I/O ports at e000
[virtual] Expansion ROM at 000c0000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
Hmm. Any idea on this one?
Your driver install is broken. without knowing precisely how you installed the driver, possibly the complete history of your machine, as well as any logs associated with the driver install, I’m not sure I’m able to help further. Anyway that is why you are getting the blender error.
Well, since I install everything with the packet manager, I can provide detailed infos of my installations, that are completely reproducible.
These are the relevant installed packages:
cuda-command-line-tools-10-2-10.2.89-1.x86_64
cuda-compiler-10-2-10.2.89-1.x86_64
cuda-cudart-10-2-10.2.89-1.x86_64
cuda-cudart-dev-10-2-10.2.89-1.x86_64
cuda-cufft-10-2-10.2.89-1.x86_64
cuda-cufft-dev-10-2-10.2.89-1.x86_64
cuda-cuobjdump-10-2-10.2.89-1.x86_64
cuda-cupti-10-2-10.2.89-1.x86_64
cuda-curand-10-2-10.2.89-1.x86_64
cuda-curand-dev-10-2-10.2.89-1.x86_64
cuda-cusolver-10-2-10.2.89-1.x86_64
cuda-cusolver-dev-10-2-10.2.89-1.x86_64
cuda-cusparse-10-2-10.2.89-1.x86_64
cuda-cusparse-dev-10-2-10.2.89-1.x86_64
cuda-documentation-10-2-10.2.89-1.x86_64
cuda-driver-dev-10-2-10.2.89-1.x86_64
cuda-gdb-10-2-10.2.89-1.x86_64
cuda-libraries-10-2-10.2.89-1.x86_64
cuda-libraries-dev-10-2-10.2.89-1.x86_64
cuda-license-10-2-10.2.89-1.x86_64
cuda-memcheck-10-2-10.2.89-1.x86_64
cuda-misc-headers-10-2-10.2.89-1.x86_64
cuda-npp-10-2-10.2.89-1.x86_64
cuda-npp-dev-10-2-10.2.89-1.x86_64
cuda-nsight-10-2-10.2.89-1.x86_64
cuda-nsight-compute-10-2-10.2.89-1.x86_64
cuda-nsight-systems-10-2-10.2.89-1.x86_64
cuda-nvcc-10-2-10.2.89-1.x86_64
cuda-nvdisasm-10-2-10.2.89-1.x86_64
cuda-nvgraph-10-2-10.2.89-1.x86_64
cuda-nvgraph-dev-10-2-10.2.89-1.x86_64
cuda-nvjpeg-10-2-10.2.89-1.x86_64
cuda-nvjpeg-dev-10-2-10.2.89-1.x86_64
cuda-nvml-dev-10-2-10.2.89-1.x86_64
cuda-nvprof-10-2-10.2.89-1.x86_64
cuda-nvprune-10-2-10.2.89-1.x86_64
cuda-nvrtc-10-2-10.2.89-1.x86_64
cuda-nvrtc-dev-10-2-10.2.89-1.x86_64
cuda-nvtx-10-2-10.2.89-1.x86_64
cuda-nvvp-10-2-10.2.89-1.x86_64
cuda-samples-10-2-10.2.89-1.x86_64
cuda-sanitizer-api-10-2-10.2.89-1.x86_64
cuda-toolkit-10-2-10.2.89-1.x86_64
cuda-tools-10-2-10.2.89-1.x86_64
cuda-visual-tools-10-2-10.2.89-1.x86_64
nvidia-computeG05-440.59-34.1.x86_64
nvidia-gfxG05-kmp-default-440.59_k5.5.2_1-34.5.x86_64
nvidia-glG05-440.59-34.1.x86_64
x11-video-nvidiaG05-440.59-34.1.x86_64
The cuda packages are from:
http://developer.download.nvidia.com/compute/cuda/repos/opensuse15/x86_64
The installed packages are unchanged, apart from these (expected, modified from rpm post section):
kuno:~# rpm -V $(rpmg 'nvidia|cuda')
.......T. c /etc/modprobe.d/50-nvidia-default.conf
.......T. /usr/lib64/xorg/modules/drivers/nvidia_drv.so
This is an openSUSE Tumbleweed 20200214 (most current, Linux Kernel 5.5.2).
The installation doesn’t trigger any messages, apart from the license:
2020-02-19 14:53:54|command|root@kuno|'zypper' '-v' 'in' 'cuda-command-line-tools-10-2-10.2.89-1.x86_64' 'cuda-compiler-10-2-10.2.89-1.x86_64' 'cuda-cudart-10-2-10.2.89-1.x86_64' 'cuda-cudart-dev-10-2-10.2.89-1.x86_64' 'cuda-cufft-10-2-10.2.89-1.x86_64' 'cuda-cufft-dev-10-2-10.2.89-1.x86_64' 'cuda-cuobjdump-10-2-10.2.89-1.x86_64' 'cuda-cupti-10-2-10.2.89-1.x86_64' 'cuda-curand-10-2-10.2.89-1.x86_64' 'cuda-curand-dev-10-2-10.2.89-1.x86_64' 'cuda-cusolver-10-2-10.2.89-1.x86_64' 'cuda-cusolver-dev-10-2-10.2.89-1.x86_64' 'cuda-cusparse-10-2-10.2.89-1.x86_64' 'cuda-cusparse-dev-10-2-10.2.89-1.x86_64' 'cuda-documentation-10-2-10.2.89-1.x86_64' 'cuda-driver-dev-10-2-10.2.89-1.x86_64' 'cuda-gdb-10-2-10.2.89-1.x86_64' 'cuda-libraries-10-2-10.2.89-1.x86_64' 'cuda-libraries-dev-10-2-10.2.89-1.x86_64' 'cuda-license-10-2-10.2.89-1.x86_64' 'cuda-memcheck-10-2-10.2.89-1.x86_64' 'cuda-misc-headers-10-2-10.2.89-1.x86_64' 'cuda-npp-10-2-10.2.89-1.x86_64' 'cuda-npp-dev-10-2-10.2.89-1.x86_64' 'cuda-nsight-10-2-10.2.89-1.x86_64' 'cuda-nsight-compute-10-2-10.2.89-1.x86_64' 'cuda-nsight-systems-10-2-10.2.89-1.x86_64' 'cuda-nvcc-10-2-10.2.89-1.x86_64' 'cuda-nvdisasm-10-2-10.2.89-1.x86_64' 'cuda-nvgraph-10-2-10.2.89-1.x86_64' 'cuda-nvgraph-dev-10-2-10.2.89-1.x86_64' 'cuda-nvjpeg-10-2-10.2.89-1.x86_64' 'cuda-nvjpeg-dev-10-2-10.2.89-1.x86_64' 'cuda-nvml-dev-10-2-10.2.89-1.x86_64' 'cuda-nvprof-10-2-10.2.89-1.x86_64' 'cuda-nvprune-10-2-10.2.89-1.x86_64' 'cuda-nvrtc-10-2-10.2.89-1.x86_64' 'cuda-nvrtc-dev-10-2-10.2.89-1.x86_64' 'cuda-nvtx-10-2-10.2.89-1.x86_64' 'cuda-nvvp-10-2-10.2.89-1.x86_64' 'cuda-samples-10-2-10.2.89-1.x86_64' 'cuda-sanitizer-api-10-2-10.2.89-1.x86_64' 'cuda-toolkit-10-2-10.2.89-1.x86_64' 'cuda-tools-10-2-10.2.89-1.x86_64' 'cuda-visual-tools-10-2-10.2.89-1.x86_64'|
# 2020-02-19 14:53:54 cuda-license-10-2-10.2.89-1.x86_64.rpm installed ok
# Additional rpm output:
# *** LICENSE AGREEMENT ***
# By using this software you agree to fully comply with the terms and
# conditions of the EULA (End User License Agreement). The EULA is located
# at /usr/local/cuda-10.2/doc/EULA.txt. The EULA can also be found at
# http://docs.nvidia.com/cuda/eula/index.html. If you do not agree to the
# terms and conditions of the EULA, do not use the software.
2020-02-19 14:53:54|install|cuda-license-10-2|10.2.89-1|x86_64|root@kuno|cuda|60fc7a57037076d5d9efa995cdb2d9e82153a154|
2020-02-19 14:53:56|install|libcublas10|10.2.2.89-1|x86_64||cuda|780d19fe9ac8f218f85e66c23e95b7322fdfc73c|
2020-02-19 14:53:56|install|cuda-sanitizer-api-10-2|10.2.89-1|x86_64|root@kuno|cuda|c623779fe51fe72c40252678914062a0093db3cd|
2020-02-19 14:53:57|install|cuda-nvtx-10-2|10.2.89-1|x86_64|root@kuno|cuda|af5004f7c6f8c73233369908ad9f70454151259b|
2020-02-19 14:53:57|install|cuda-nvrtc-10-2|10.2.89-1|x86_64|root@kuno|cuda|050989b32ad89f8980546257853949bc106ff544|
2020-02-19 14:53:57|install|cuda-nvprune-10-2|10.2.89-1|x86_64|root@kuno|cuda|0c874fb8b41b7445abf7244381f77c61e58c96bb|
2020-02-19 14:53:58|install|cuda-nvprof-10-2|10.2.89-1|x86_64|root@kuno|cuda|a867b7a3274c1fd8229ecfb8cff5fae7070593f1|
2020-02-19 14:53:58|install|cuda-nvml-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|3c09d167335e2a3b27c09e92ae95842e41548b5e|
2020-02-19 14:53:58|install|cuda-nvjpeg-10-2|10.2.89-1|x86_64|root@kuno|cuda|f1ad04391d9a02fe86ed19dae9f297c49c1e4285|
2020-02-19 14:54:02|install|cuda-nvgraph-10-2|10.2.89-1|x86_64|root@kuno|cuda|b0209acf16859903c229c74c1d1cd5f171cf4c61|
2020-02-19 14:54:02|install|cuda-nvdisasm-10-2|10.2.89-1|x86_64|root@kuno|cuda|0afddb72ea10f87ae76f2a2d6e261d0214b530ec|
2020-02-19 14:54:02|install|cuda-nsight-systems-10-2|10.2.89-1|x86_64|root@kuno|cuda|31e0db44252e014eef1cc7f6787579b0d0903e37|
2020-02-19 14:54:02|install|cuda-nsight-compute-10-2|10.2.89-1|x86_64|root@kuno|cuda|aea85f847edaa6374829e908e739aae54ae12d96|
2020-02-19 14:54:09|install|cuda-nsight-10-2|10.2.89-1|x86_64|root@kuno|cuda|740ad85471ecb3e7cb247559d759751ef95c024a|
2020-02-19 14:54:13|install|cuda-npp-10-2|10.2.89-1|x86_64|root@kuno|cuda|6516e66974e6527580299744a65c57023192918e|
2020-02-19 14:54:14|install|cuda-misc-headers-10-2|10.2.89-1|x86_64|root@kuno|cuda|59e977f093762bf0996a38b129f5443f7677ee8b|
2020-02-19 14:54:14|install|cuda-memcheck-10-2|10.2.89-1|x86_64|root@kuno|cuda|6ee7ec8d258d5bc492f4924bd5057753a99cf8cf|
2020-02-19 14:54:14|install|cuda-driver-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|6628c946ab0bd019aa1ebe5ac84a2d6e19a76ca7|
2020-02-19 14:54:17|install|cuda-cusparse-10-2|10.2.89-1|x86_64|root@kuno|cuda|1f24640c7973722f3232a1117405106ccb02e93e|
2020-02-19 14:54:23|install|cuda-cusolver-10-2|10.2.89-1|x86_64|root@kuno|cuda|5a05d3276a15130b17d00c65ff63894fe72747be|
2020-02-19 14:54:25|install|cuda-curand-10-2|10.2.89-1|x86_64|root@kuno|cuda|79272df299e24b309adaa6abf56885bc042963be|
2020-02-19 14:54:25|install|cuda-cuobjdump-10-2|10.2.89-1|x86_64|root@kuno|cuda|2cd999a75e371ab12f5174f52e584ddac25687fa|
2020-02-19 14:54:28|install|cuda-cufft-10-2|10.2.89-1|x86_64|root@kuno|cuda|1fbac8f8e83aeea13857c631ff95d2ac29988bc3|
2020-02-19 14:54:29|install|cuda-cudart-10-2|10.2.89-1|x86_64|root@kuno|cuda|666e856e97845121411a0fef87ab5597a9aa1edf|
2020-02-19 14:54:31|install|libcublas-devel|10.2.2.89-1|x86_64||cuda|e6d42d87b5f6829770f8a170c7b4c821f30eda3d|
2020-02-19 14:54:31|install|cuda-nvrtc-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|11164ed0e08f64a71e131288b8a01f5169c2f270|
2020-02-19 14:54:31|install|cuda-nvjpeg-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|7509be87f4eef6481044c66a01a69871593df75a|
2020-02-19 14:54:34|install|cuda-nvgraph-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|873cc260fd8d65a73b50afd8010ce7efc0a6391a|
2020-02-19 14:54:38|install|cuda-nvvp-10-2|10.2.89-1|x86_64|root@kuno|cuda|ccb19a7e72560f3130af99d2f939a6249686d291|
2020-02-19 14:54:41|install|cuda-npp-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|4b45fac887ffa6d965127f6c5110e086de08c001|
2020-02-19 14:54:44|install|cuda-nvcc-10-2|10.2.89-1|x86_64|root@kuno|cuda|2de563561c9e73404e68eee4eb2e43d90d541d2d|
2020-02-19 14:54:51|install|cuda-cusparse-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|97e400b183a97d59ceddf1e1d11b303fc4b32faf|
2020-02-19 14:54:53|install|cuda-cusolver-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|c70d619e1420ebfbd36834ed52cd0afcb93eee92|
2020-02-19 14:54:54|install|cuda-curand-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|b0338c26424697432201dc4859c5370408c0d34f|
2020-02-19 14:54:54|install|cuda-gdb-10-2|10.2.89-1|x86_64|root@kuno|cuda|5d2cb0632d164d1f3ad8ed5b0f97585a7e57c817|
2020-02-19 14:55:01|install|cuda-cufft-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|099c1d9615b0c7e624d20625f2b2084fcf65281d|
2020-02-19 14:55:01|install|cuda-libraries-10-2|10.2.89-1|x86_64|root@kuno|cuda|af3022da8f442ebadf9b087a300c2991d05383cd|
2020-02-19 14:55:02|install|cuda-cudart-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|28bea224effeda2318e6ee66142288276f80afbf|
2020-02-19 14:55:02|install|cuda-compiler-10-2|10.2.89-1|x86_64|root@kuno|cuda|8cf8663848470a7f8bde24bea0fe593a69b5e4f9|
2020-02-19 14:55:02|install|cuda-visual-tools-10-2|10.2.89-1|x86_64|root@kuno|cuda|cd24b4d1e8d839b32d4bde8e0bc06787ca5eaa05|
2020-02-19 14:55:07|install|cuda-samples-10-2|10.2.89-1|x86_64|root@kuno|cuda|a884ad29f016bae2221ffaf918385aa504238ef7|
2020-02-19 14:55:07|install|cuda-libraries-dev-10-2|10.2.89-1|x86_64|root@kuno|cuda|48bb3729b03c912c90a98a6f24893260bb5eb275|
2020-02-19 14:55:08|install|cuda-cupti-10-2|10.2.89-1|x86_64|root@kuno|cuda|364f70bdca3f58067ab7c8156517cb6a64f8791d|
2020-02-19 14:55:15|install|cuda-documentation-10-2|10.2.89-1|x86_64|root@kuno|cuda|5c5f895ac4fc4ee9d24976c291e9f90f47bb1e20|
2020-02-19 14:55:15|install|cuda-command-line-tools-10-2|10.2.89-1|x86_64|root@kuno|cuda|dc045471e5ae6c8eafbb937f397ed2d3c3fbeb6b|
2020-02-19 14:55:15|install|cuda-tools-10-2|10.2.89-1|x86_64|root@kuno|cuda|99e459d95c7560d8fc101a141ea85e5ba035f41f|
2020-02-19 14:55:15|install|cuda-toolkit-10-2|10.2.89-1|x86_64|root@kuno|cuda|71b7e2188dbdd781c872dc8e81d9ef95de4fc357|
Let me know, what other details you’re interested in.
We are not interested in CUDA at this point. We are interested in the driver install.
None of that info shows me how you installed the driver, or where your driver packages came from. The driver packages you do show did not come from the repo you indicate - you can easily check that yourself.
OpenSuse tumbleweed is not an officially supported distro for CUDA. My suggestion would be to follow the linux install guide carefully:
https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html
get your installers from https://www.nvidia.com/getcuda
Finally fixed it. For some reason, an old/stray /etc/modprobe.d/nvidia.conf file failed to initialize /dev/nvidia-uvm correctly.
Sorry for the churn.
Will know, where to look the next time…
Fri Dec 10 02:50:54 2021
| NVIDIA-SMI 495.44 Driver Version: 495.44 CUDA Version: 11.5 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:02:00.0 On | N/A |
| 40% 26C P8 N/A / 75W | 368MiB / 4035MiB | 0% Default |
| | | N/A |
"Read prefs: /home/rivelino/.config/blender/3.0/config/userpref.blend
CUDA cuInit: Unknown CUDA error value
Saved session recovery to ‘/tmp/quit.blend’
Writing userprefs: ‘/home/rivelino/.config/blender/3.0/config/userpref.blend’ ok
Info: Preferences saved
Blender quit
Here I am having the same problem, I installed the driver, from the nvidia website, NVIDIA-Linux-x86_64-495.44.run, one thing I noticed when testing Debian is that with the 460.91.03 driver Blender recognizes the GPU(gtx1050ti) , since the 470 and 495 do not.
Here I am having the same problem, I installed the driver, from the nvidia website, NVIDIA-Linux-x86_64-495.44.run, one thing I noticed when testing Debian is that with the 460.91.03 driver Blender recognizes the GPU(gtx1050ti) , already the 470 and 495 no.
I’ve tried everything and still haven’t had success, it only works with the 460.91.03 driver
