Currently I’m evaluating a trial version of CUDA Fortran compiler. I have just tested a sample source code “cufinfo.cuf” that can be found in C:\Program Files\PGI\win32\10.5\samples after installation.
program cufinfo
use cudafor
integer istat, num, numdevices
type(cudadeviceprop) :: prop
istat = cudaGetDeviceCount(numdevices)
do num = 0, numdevices-1
istat = cudaGetDeviceProperties(prop, num)
call printDeviceProperties(prop, num)
end do
end
subroutine printDeviceProperties(prop, num)
use cudafor
integer num
ilen = verify(prop%name, ' ', .true.)
write (*,900) "Device Number: " ,num
write (*,901) "Device Name: " ,prop%name(1:ilen)
write (*,903) "Total Global Memory: ",real(prop%totalGlobalMem)/1e9," Gbytes"
write (*,902) "sharedMemPerBlock: " ,prop%sharedMemPerBlock," bytes"
write (*,900) "regsPerBlock: " ,prop%regsPerBlock
write (*,900) "warpSize: " ,prop%warpSize
write (*,900) "maxThreadsPerBlock: " ,prop%maxThreadsPerBlock
write (*,904) "maxThreadsDim: " ,prop%maxThreadsDim
write (*,904) "maxGridSize: " ,prop%maxGridSize
write (*,903) "ClockRate: " ,real(prop%clockRate)/1e6," GHz"
write (*,902) "Total Const Memory: " ,prop%totalConstMem," bytes"
write (*,905) "Compute Capability Revision: ",prop%major,prop%minor
write (*,902) "TextureAlignment: " ,prop%textureAlignment," bytes"
write (*,906) "deviceOverlap: " ,prop%deviceOverlap
write (*,900) "multiProcessorCount: ",prop%multiProcessorCount
write (*,906) "integrated: " ,prop%integrated
write (*,906) "canMapHostMemory: " ,prop%canMapHostMemory
900 format (a,i0)
901 format (a,a)
902 format (a,i0,a)
903 format (a,f5.3,a)
904 format (a,2(i0,1x,'x',1x),i0)
905 format (a,i0,'.',i0)
906 format (a,l0)
return
end
After I compile this code by “pgfortran -ta=nvidia cufinfo.cuf”, two output files (object file library, exports library file) are not generated. It seems there is a problem with compiling or linking cuda fortran code, because when I tried a standard fortran code (f3.f90 in C:\Program Files\PGI\win32\10.5\samples), it worked fine.
Please give me an advice on what’s wrong and what I’m missing.
I’d greatly appreciate for your answer.
odyssey
