Cuda mpi fortran
when I use cuda fortran with mpi and compiling target , it always print do note find cudagetdevicecount_ and `cudagetdeviceproperties_’ ,please help me slove it
subroutine get_gpu_attribute()
            type(cudaDeviceProp) :: prop
            integer ::nDevices=0,i,istat
            istat=cudaGetDeviceCount(nDevices)
            write(*,"('the gpu num is', i3)"), nDevices
            do i=0,nDevices-1
                    write(*,"('device number: ',i0)") i
                    istat=cudaGetDeviceProperties(prop,i)
                    write(*,"('Compute Capability :',i0,'.',i0)") prop%major,prop%minor
                    write(*,"('number of multiprocessors :',i0)") prop%multiProcessorCount
                    write(*,"('Max Threads per Multiprocessors :',i0)") prop%maxThreadsPerMultiprocessor
                    write(*,"('Global Memory (GB)',i5)") prop%totalGlobalMem/1024**3
                    write(*,"('Execution Configuration Limits')")
                    write(*,"('Max Grid Dims :'2(i0,'x'),i0)") prop%maxGridSize
                    write(*,"('Max Block Dims :'2(i0,'x'),i0)") prop%maxThreadsDim
                    write(*,"('Max Threads per Block:',i0)") prop%maxThreadsPerBlock
            end do
end subroutine get_gpu_attribute
program main
use mpi
use cudafor
use gModule
character * (MPI_MAX_PROCESSOR_NAME) processor_name
integer :: myid , numprocs,namelen,rc,ierr,istat
call mpi_init(ierr)
call mpi_comm_rank(mpi_comm_world,myid,ierr)
call mpi_comm_size(mpi_comm_world, numprocs,ierr)
call mpi_get_processor_name(processor_name,namelen,ierr)
print * ,'hello world !process ',myid,processor_name
call get_gpu_attributes()
call mpi_finalize(rc)
end program main
makefile :
CC = mpif90
NVCC =pgfortran
CFLAGS+= -O3
LDFLAGS+= -L/usr/local/cuda/lib64 -lcula -lcula_pgfortran -llapack -lblas
NVCCFLAGS= -I /usr/local/cuda/include
all: target
target: gModule.o main.o
$(CC) $(LDFLAGS+) $^ -o $@
%.o : %.cuf
$(NVCC) $(LDFLAGS+) -o $@ -c $^
%.o: %.f90
$(CC) $(NVCCFLAGS) $(CFLAGS) -o $@ -c $^
clean:
rm *mod
rm *.o
the result of make :
pgfortran -o gModule.o -c gModule.cuf
mpif90 -I /usr/local/cuda/include -O3 -o main.o -c main.f90
mpif90 gModule.o main.o -o target
gModule.o: In function get_gpu_attribute': /g1/u/liuzhe/program/mpi/gModule.cuf:10: undefined reference to cudagetdevicecount_’
/g1/u/liuzhe/program/mpi/gModule.cuf:14: undefined reference to cudagetdeviceproperties_' main.o: In function main’:
/g1/u/liuzhe/program/mpi/main.f90:12: undefined reference to `get_gpu_attributes
which pgfortran mpif90
/g1/app/compiler/pgi194/linux86-64-llvm/19.4/bin/pgfortran
/g1/app/compiler/pgi194/linux86-64-llvm/2019/mpi/openmpi-3.1.3/bin/mpif90
You need to add “use cudafor” in the subroutine (or module it’s contained in) so CUDA routine interfaces are used.
There’s other errors as well. Given you “use gModule”, I assume you meant to include the subroutine in a module. Also, the subroutine name is “get_gpu_attribute” but are calling “get_gpu_attributes”.
Here’s the working version:
% cat test.cuf
module gModule
 use cudafor
 contains
            do i=0,nDevices-1
            end do
end module gModule
program main
use mpi
use cudafor
use gModule
call mpi_init(ierr)
call get_gpu_attribute()
end program main
% mpif90 test.cuf; mpirun -np 1 ./a.out
 hello world !process             0
 dev-sky5
the gpu num is  4
device number: 0
Compute Capability :7.0
number of multiprocessors :80
Max Threads per Multiprocessors :2048
Global Memory (GB)   15
Max Grid Dims :2147483647x65535x65535
Max Block Dims :1024x1024x64
Max Threads per Block:1024
device number: 1
device number: 2
device number: 3
Hope this helps,
Mat
thank you very much, the problem troubled me three days . i work well according your method ,but ,i have a question . the problem is printing “undefined reference to `cudagetdevicecount_'” when i use makefile(the makefile is follow), when using mpif90 gModule.cuf main.f90 , it will work right ,please tell me why , so i can sovle it forever .
makefile is :
CC = mpif90
NVCC =mpif90
CFLAGS+= -O3
LDFLAGS+=
all: target
gModule.o : gModule.cuf
$(NVCC) -c $^
main.o: main.f90
$(CC) $(NVCCFLAGS) $(CFLAGS) -c $^
clean:
rm *mod
rm *.o
Add the “-Mcuda” flag to your LDFLAGS.
For files with the “.cuf” extension, “-Mcuda” (i.e. enable CUDA Fortran) is implied. However for other file extensions, like “.o”, the compiler doesn’t know you’re using CUDA Fortran so isn’t adding the CUDA Fortran runtime libraries.
thank you very much ,i benefit very much from your answer , and hope you give me more help when you are free from work
