Mpif90+pgf90 compilation problem
Hello everyone, as the title shows, fortran write MPI parallel program, part of the program I rewritten into cudaFortran program running on the GPU, .cuf, then compile, use mpif90 to compile mpifortran program, pgf90 compile to compile cudafortran program, There is no problem compiling, but the link fails. I want to know how to implement MPI+cudafortran hashing.
The procedure is as follows:
      program hello_world
      include 'mpif.h'
      integer ierr,num_procs,myid
      integer a(2,2),b(2),c(2)
      a=2
      b=1
      c=0
      call MPI_INIT(ierr)
      call MPI_COMM_RANK(MPI_COMM_WORLD,myid,ierr)
      call MPI_COMM_SIZE(MPI_COMM_WORLD,num_procs,ierr)
      print*,"Hello world!I'm process",myid,"out of",
     &       num_procs,"processes."
      call add(a,b,c)
      if(myid.eq.0)then
       print*,'c=',c(1),c(2)
      endif
      call MPI_FINALIZE(ierr)
      end program hello_world
      subroutine add(a,b,c)
      use cudafor
      use a_m
      implicit none
      integer,device::a_d(2,2),b_d(2),c_d(2)
      a_d=a
      b_d=b
      c_d=c
      call add1<<<1,2>>>(a_d,b_d,c_d)
      a=a_d
      b=b_d
      c=c_d
      end subroutine add
     module a_m
      use cudafor
      contains
         attributes(global) subroutine add1(a_d,b_d,c_d)
         implicit none
         integer,device::b_d(2)
         integer,device::c_d(2)
         integer ii
         ii=threadIdx%x
         if(ii.le.2)then
          c_d(ii)=a_d(ii,ii)*b_d(ii)
         endif
         return
         end subroutine add1
      end module a_m
makefile:
CUDA_INSTALL_PATH=/home/myfan/PGI/linux86-64/18.4
MPI_INSTALL_PATH=/opt/mpich2-1.4.1p1
PGF90=$(CUDA_INSTALL_PATH)/bin/pgf90
MPIF90=$(MPI_INSTALL_PATH)/bin/mpif90
LDFLAGS= -L$(CUDA_INSTALL_PATH)/lib
LIB=
FFILES=hello_world.f90
CUFILES=a_m.cuf add.cuf
OBJECTS=hello_world.o a_m.o add.o
EXENAME= test.x
ALL:
$(MPIF90) -c $(FFILES)
$(PGF90) -c $(CUFILES)
$(MPIF90) -o $(EXENAME) $(LDFLAGS) $(LIB) $(OBJECTS)
CLEAN:
rm -f *.o $(exename) *.mod
Compile without problems, link out the problem:
a_m.o: In function a_m_add1_': a_m.cuf:(.text+0x32): undefined reference to cudaSetupArgument’
a_m.cuf:(.text+0x47): undefined reference to cudaSetupArgument' a_m.cuf:(.text+0x5c): undefined reference to cudaSetupArgument’
a_m.cuf:(.text+0x68): undefined reference to cudaLaunch' a_m.o: In function __..acc_cuda_funcreg_constructor_1END’:
a_m.cuf:(.text+0xb8): undefined reference to __pgi_cuda_register_fat_binary' a_m.cuf:(.text+0x10c): undefined reference to cudaRegisterFunction’
a_m.o: In function .STATICS4': a_m.cuf:(.data+0x110): undefined reference to cudadevice
a_m.cuf:(.data+0x118): undefined reference to cudafor_' a_m.cuf:(.data+0x120): undefined reference to iso_c_binding
a_m.cuf:(.data+0x128): undefined reference to pgi_acc_common_' a_m.o:(.init+0xb): undefined reference to Mcuda_compiled’
add.o: In function add_': (.text+0x2a): undefined reference to pgf90_dev_auto_alloc04’
add.o: In function add_': (.text+0x3f): undefined reference to pgf90_dev_auto_alloc04’
add.o: In function add_': (.text+0x54): undefined reference to pgf90_dev_auto_alloc04’
add.o: In function add_': /home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_copyin’
/home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_copyin' /home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_copyin’
/home/myfan/test/mpi/./add.cuf:7: undefined reference to __pgiLaunchKernel' /home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_copyout’
/home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_copyout' /home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_copyout’
/home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_auto_dealloc' /home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_auto_dealloc’
/home/myfan/test/mpi/./add.cuf:7: undefined reference to pgf90_dev_auto_dealloc' add.o: In function .C1_379’:
add.cuf:(.data+0x28): undefined reference to cudafor_' add.cuf:(.data+0x38): undefined reference to iso_c_binding_’
add.cuf:(.data+0x40): undefined reference to pgi_acc_common_' add.cuf:(.data+0x48): undefined reference to f90_compiled’
add.o:(.init+0x1): undefined reference to `Mcuda_compiled’
make: *** [ALL] Error 1
It should be a problem with lib. I didn’t put the lib library in my makefile. But which library should be linked specifically, how to get it or not, I want to ask.
And Can someone give me a reference Makefile?
Hi M_yeah,
Which Fortran compiler is your mpif90 configured to use?
You’ll want to make sure that it’s using pgfortran (or pgf90) since different objects compiled by Fortran compilers aren’t inter-operable.
Second, you’ll want to add the flag “-Mcuda” to your link options (LDFLAGS). The compiler knows to implicitly add this when it sees it’s compiling a file with the “.cuf” suffix. But with objected files (.o), it doesn’t know you’re using CUDA Fortran. Using “-Mcuda” will have the compiler implicitly add the correct CUDA Fortran libraries to your link (the symbols you show are all found in the CUDA Fortran runtime libraries).
Hope this helps,
Mat
I have successfully solved this problem. The specific approach is:
Compile the parallel program with the mpif90 that comes with the PGI compiler, then compile the .cu file with pgf90, then add -Mcuda at the link.
The specific makefile is as follows:
CUDA_INSTALL_PATH=/home/myfan/Desktop/PGI/linux86-64/18.4
MPI_INSTALL_PATH=/home/myfan/Desktop/PGI/linux86-64/18.4/mpi/openmpi-2.1.2
#LINK1= /home/myfan/Desktop/PGI/linux86-64/18.4/lib/libcudafor.a
CUDALIB=-L/home/myfan/Desktop/PGI/linux86-64/2018/cuda/8.0/lib64 -lcudart
EXENAME= test.x
ALL:
        $(PGF90)  $(CUDALIB) $(CUDAINC) -c $(CUFILES)
        $(MPIF90) $(OBJECTS) -Mcuda $(CUDALIB) $(CUDAINC) -o test.x
.PHONY clean:
clean:
        -rm -rf *.o
        -rm -rf *.mod
        -rm -rf test.x
Thanks a lot~~
I too had this problem. I could solve with your answer. Thank you. I was looking for latest documentation on compilation, linking procedure with options
Hello, very helpful thread. I tried compiling your code in the manner you described. I ran into issue with:
/apps/pgi/linux86-64/18.7/lib/libcudafor91.so: undefined reference to cudaLaunchCooperativeKernel
Full output from ‘make’:
/apps/mpi/openmpi/openmpi-4.0.2/bin/mpif90 -c hello_world.f90
/apps/pgi/linux86-64/18.7/bin/pgf90 -L/apps/pgi/linux86-64/2018/cuda/8.0/lib64 -lcudart -c a_m.cuf add.cuf
a_m.cuf:
add.cuf:
/apps/mpi/openmpi/openmpi-4.0.2/bin/mpif90 hello_world.o a_m.o add.o -Mcuda -L/apps/pgi/linux86-64/2018/cuda/8.0/lib64 -lcudart -o test.x
/apps/pgi/linux86-64/18.7/lib/libcudafor91.so: undefined reference to `cudaLaunchCooperativeKernel’
pgacclnk: child process exit status 1: /usr/bin/ld
make: *** [Makefile:16: ALL] Error 2
Any help/guidance to get through this error would be helpful.
Thank you.
If I remember correctly, “cudaLaunchCooperativeKernel” wasn’t added until CUDA 9.0, but you’re explicitly linking with CUDA 8.0.
You should try removing “-L/apps/pgi/linux86-64/2018/cuda/8.0/lib64 -lcudart” and let the compiler link against the correct CUDA runtime library.
If you do need to override the default CUDA version used (this is determined by the CUDA driver installed on the compilation system and likely 9.0 in this case), then use the flag “-Mcuda=cuda8.0”.
Hi MatColgrove. Thank you for your advice! I simply commented this line in the Makefile:
#CUDALIB=-L/apps/pgi/linux86-64/2018/cuda/8.0/lib64 -lcudart
And voila, it worked!
I also tried updating the library reference to 9.0 and it also worked [to confirm that “you were remembering correctly” ;-) ]
CUDALIB=-L/apps/pgi/linux86-64/2018/cuda/9.0/lib64 -lcudart
Thanks again for such a quick reply!
