Hello. I am very new to CUDA, especially with Fortran. I am also a novice with makefiles, generally borrowing from others. Hopefully I’m not making an embarrassingly simple mistake!
I am having an issue compiling a project that uses both CUDA and MPI. I am using the nvfortran compiler for CUDA and mpif90 for MPI. Basically, from my main program I want to “use CUDA_module” and “use MPI_module”. However, when compiling my main f90 file with mpif90 I get the error:
mpif90 -O0 -Mbounds -traceback -cuda -c main.f90
ifort: command line warning #10006: ignoring unknown option ‘-Mbounds’
ifort: command line warning #10006: ignoring unknown option ‘-cuda’
main.f90(4): error #7013: This module file was not generated by any release of this compiler. [CUDAMOD]
use cudamod
I have seen the following threads which are similar:
However the first two are at the linking stage, while I’m still compiling, and either way my -Mbounds and -cuda flags are being ignored anyways. I’m not sure if the last one is an issue since based on the table at
it seems like mpif90 and nvfortran should be compatible. Note I am not at UCAR but using a different computing cluster, which may be why I do not see compatibility?
I am trying this with a very simple code that essentially just initializes MPI, then initializes a GPU, then prints a bunch of hello worlds before finalizing MPI. The codes are:
main.f90
program mpicuda
use mpimod use cudamod implicit none integer :: i, rank call mpiinit(rank) call usegpu(rank) do i = 1,10 print*,"Hello world ",i," from rank ",rank end do call finilizempi()end program
mpimod.f90
module mpimod
use MPI contains subroutine mpiinit(myrank) implicit none integer, intent(out) :: myrank integer :: rank, ierr, num_procs call MPI_INIT(ierr) call MPI_COMM_SIZE(MPI_COMM_WORLD, num_procs, ierr) call MPI_COMM_RANK(MPI_COMM_WORLD, rank ,ierr) myrank = rank return end subroutine mpiinit subroutine finalizempi() implicit none integer :: ierr call MPI_FINALIZE(ierr) return end subroutine finalizempiend module mpimod
cudamod.cuf
module cudamod
use cudafor implicit none contains subroutine usegpu(rank) implicit none integer, intent(in) :: rank integer :: istat, nblock, ngrid ngrid = 32 nblock = 32 if (rank .eq. 0) then istat = cudaSetDevice(0) end if call gpukern<<<ngrid, nblock>>>() return end subroutine usegpu attributes(global) subroutine gpukern() implicit none integer :: i i = (blockidx%x-1)*blockdim%x + threadidx%x return end subroutine gpukernend module cudamod
Makefile
EXE:=mpigpu.exe
FCCUDA:=/bin/nvfortran
FCMPI:=mpif90Debug Flags
FCFLAGS:=-O0 -Mbounds -traceback
FILES:= cudamod.o mpimod.o main.o
MODS:=$(wildcard *.mod)
UNAME_S:=$(shell uname -n)
RM:=rm -fv.SUFFIXES: .o .f .f90 .cuf
all: ${EXE}
${EXE}: ${FILES} ${MODS}
${FCMPI} -cuda -o $@ ${FILES}cudamod.o:
${FCCUDA} ${FCFLAGS} -cuda -c cudamod.cufmpimod.o:
${FCMPI} ${FCFLAGS} -cuda -c mpimod.f90main.o:
${FCMPI} ${FCFLAGS} -cuda -c main.f90%.mod: %.f90
@echo “Some modules are out of date. Do clean and then recompile”
${RM} $@ ${EXE}.PHONY: clean
clean:
${RM} *.o
${RM} *.mod
${RM} ${EXE}
It doesn’t seem like there should be an issue. I have also tried -fc=/bin/nvfortran in the makefile to get mpif90 to use the right compiler, but then I have a similar error output as in the third thread I linked above (NVFORTRAN-F-0004-Corrupt or Old Module file). Is it impossible to get a file compiled with mpif90 to ‘use’ one with nvfotran? What would be my alternative? Is my version of mpif90 out of date and so doesn’t recognize nvfotran? I have done something similar in C (mpixx + nvcc) with no issues getting them to compile and link, but there I think the usage of a header file resolves issues in compiling.
EDIT: Looks like some of the spacing in the makefile copied weird, but all the tabbing is fine in my file.
