Cuda-gdb client via the gdb/mi interface
I’m debugging the following program using cuda-gdb 12.8:
#include <cstdio>
__global__ void kernel() {
  printf("ok\n"); //break
  printf("ok\n");
int main() {
  kernel<<<1, 1>>>();
  cudaDeviceSynchronize();
  return 0;
It looks like stepping via gdb/mi doesn’t work. When the breakpoint is reached, cuda-gdb reports that the program is stopped on thread-id=1:
<*stopped,CudaFocus={device="0",sm="0",warp="0",lane="0",kernel="0",grid="1",blockIdx="(0,0,0)",threadIdx="(0,0,0)"},reason="breakpoint-hit",disp="keep",bkptno="1",frame={addr="0x0000000701a4e610",func="kernel",args=[],file="/home/nd/w/a/CLionProjects/cuda-test/main.cu",fullname="/home/nd/w/a/CLionProjects/cuda-test/main.cu",line="4",arch="m68k"},thread-id="1",stopped-threads="all",core="10"
An attempt to step to the next line using the -exec-next command fails with the error:
>38-exec-next --thread 1
<38^error,msg="Cannot find bounds of current function"
Is it possible to use cuda-gdb via gdb/mi interface? If it is possible, what commands should be used?
Hi, @dmitry.neverov
Thanks for using cuda-gdb. Regarding to gdb/mi interface, our dev plan on documenting this in the future but at the moment it is not officially supported.
