cuda-gdb CUDA debugging hangs when non-root
This happens any time I attempt to debug CUDA when I’m anything other than root. (In fact, I only thought to try this as root right before reporting this.) Anyway, here’s a small example. First, some trivial source code:
#include <stdio.h>
#include <unistd.h>
__global__ void Nil()
   printf("short and stout.\n");
int main(int argc, char** argv)
   printf("I'm a little teapot,\n");
   Nil<<<1, 1>>>();
   cudaError_t err = cudaGetLastError();
   if (err != cudaSuccess) {
      fprintf(stderr,
              "kernel launch failure: %s (%d)\n",
              cudaGetErrorString(err), err);
      exit(-1);
   cudaThreadSynchronize();
   exit(0);
Next, the cuda-gdb session:
$ cuda-gdb
... banners ...
(cuda-gdb) b 6
Breakpoint 1 at 0x10fc: file cudanil.cu, line 6.
(cuda-gdb) r
Starting program: /some/path/cudanil
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
---HANG---
It appears that the cudbgprocess backend process crashes very soon after its creation, after it has created its pipe to communicate with cuda-gdb. And then cuda-gdb hangs indefinitely trying to open the pipe with no process on the other end.
I spotted this when testing our NightView debugger with our not-yet-released RedHawk kernel based on L4T R31.1 and with an L4T R31.1 userland. But I was able to reproduce it with the cuda-gdb on the vanilla L4T R31.1 kernel. And today I verified that it still happens with cuda-gdb on the vanilla L4T R32.1 too.
This is a known issue.
Due to some internal restrictions, you will need to execute all the tool (cuda-gdb, cupti, nvprof…) as root.
