Hello everyone,
I am trying to remotely debug the CUDA matrix multiply (matrixMul) example in Eclipse Nsight. Simply running the executable works fine and the debugging also starts. But when I want to single-step through the instructions the function call
int dev = findCudaDevice(argc, (const char **)argv);
right in the beginning of the main function leads to this output in the console
Reading /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1 from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm.so from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm_graphics.so from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0 from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvos.so from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libcuda.so.1.1.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvrm_gpu.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvrm.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm_graphics.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvrm_graphics.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvidia-fatbinaryloader.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvos.so.debug from remote target...
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvos.so.debug from remote target...
After that the application somehow hangs-up and I am not able to go on debugging.
Does anybody know a solution to this problem?
Thank you in advance!
