#0 0x00007fff5b0e7f64 in ?? () from /usr/lib/x86_64-linux-gnu/libcudadebugger.so.1
#1 0x00007fff5b0e8c26 in InitializeInjection () from /usr/lib/x86_64-linux-gnu/libcudadebugger.so.1
#2 0x00007fffb2b7efde in ?? () from /usr/lib/x86_64-linux-gnu/libcuda.so.1
#3 0x00007fffb28db91c in ?? () from /usr/lib/x86_64-linux-gnu/libcuda.so.1
#4 0x00007fffb2994210 in ?? () from /usr/lib/x86_64-linux-gnu/libcuda.so.1
#5 0x00007fffb29ef408 in ?? () from /usr/lib/x86_64-linux-gnu/libcuda.so.1
#6 0x00007fffef0813f8 in __cudart514 () from /home/ckt1010/adlab/output/lib/libailice_v3.so.5.5
#7 0x00007fffef081488 in __cudart1325 () from /home/ckt1010/adlab/output/lib/libailice_v3.so.5.5
#8 0x00007fffb02654df in __pthread_once_slow () from /usr/lib/x86_64-linux-gnu/libpthread.so.0
#9 0x00007fffef0cb379 in __cudart1597 () from /home/ckt1010/adlab/output/lib/libailice_v3.so.5.5
#10 0x00007fffef078237 in __cudart512 () from /home/ckt1010/adlab/output/lib/libailice_v3.so.5.5
#11 0x00007fffef0a4fb1 in cudaFree () from /home/ckt1010/adlab/output/lib/libailice_v3.so.5.5
#12 0x00007fffef011d2a in ailice_v3::initializeAiliceV3(ailice_v3::AiliceV3InitArgs const&) ()
#13 0x0000555555d63fb9 in adlab::prediction::main (argc=1, argv=0x7fffffffcca8)
at modules/prediction/framework/main.cc:346
#14 0x0000555555d6538e in main (argc=1, argv=0x7fffffffcca8) at modules/prediction/framework/main.cc:425
But when I use gdb or run directly it work fine.
CUDA version: 11.4
BR/Tim
Tue Oct 24 09:46:34 2023
| NVIDIA-SMI 525.60.13 Driver Version: 525.60.13 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:02:00.0 Off | N/A |
| 0% 53C P8 37W / 300W | 2822MiB / 11264MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
cuda-gdb --version:
NVIDIA (R) CUDA Debugger
11.4 release
Portions Copyright (C) 2007-2021 NVIDIA Corporation
GNU gdb (GDB) 10.1
Copyright (C) 2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Your cuda-gdb (distributed as a part of CUDA toolkit) seems to be too old for your GPU driver (you are using 11.4 toolkit with 12.0 driver). Could you try installing 12.0 CUDA toolkit: https://developer.nvidia.com/cuda-12-0-0-download-archive ?
Hi! You just need to use cuda-gdb binary from 12.0 toolkit. You should be able to install it next to the existing 11.4 toolkit. This link might help: Installing additional CUDA versions
