I have complete my algorithm, and want to integrate with CUDA graph for reducing overhead of launching several kernels in runtime.
When I tried to integrate cuSolver
EVD API with graph I got CUSOLVER_STATUS_INTERNAL_ERROR
I’ve read programming guide and didn’t see much example related to graph.
Below is an example of CUDA graph in capture mode with two nodes, one is cuSolver EVD and the other is a customized kernel.
The error will occur when calling cusolverDnCheevd
#include <iostream>
#include <cuda_runtime.h>
#include <cusolverDn.h>
#include <cuComplex.h>
#define CHECK_CUDA(call) \
do { \
cudaError_t err = call; \
if (err != cudaSuccess) { \
fprintf(stderr, "Cuda failed with error code %s at line %d in file %s\n", cudaGetErrorString(err), __LINE__, __FILE__); \
exit(EXIT_FAILURE); \
} while (0)
#define CHECK_CUSOLVER(call) \
do { \
cusolverStatus_t stat = call; \
if (stat != CUSOLVER_STATUS_SUCCESS) { \
fprintf(stderr, "CuSolver failed with error code %s at line %d in file %s\n", cusolverGetErrorString(stat), __LINE__, __FILE__); \
} while (0)
const char *cusolverGetErrorString(cusolverStatus_t error) {
switch (error) {
case CUSOLVER_STATUS_SUCCESS:
return "CUSOLVER_STATUS_SUCCESS";
case CUSOLVER_STATUS_NOT_INITIALIZED:
return "CUSOLVER_STATUS_NOT_INITIALIZED";
case CUSOLVER_STATUS_ALLOC_FAILED:
return "CUSOLVER_STATUS_ALLOC_FAILED";
case CUSOLVER_STATUS_INVALID_VALUE:
return "CUSOLVER_STATUS_INVALID_VALUE";
case CUSOLVER_STATUS_ARCH_MISMATCH:
return "CUSOLVER_STATUS_ARCH_MISMATCH";
case CUSOLVER_STATUS_MAPPING_ERROR:
return "CUSOLVER_STATUS_MAPPING_ERROR";
case CUSOLVER_STATUS_EXECUTION_FAILED:
return "CUSOLVER_STATUS_EXECUTION_FAILED";
case CUSOLVER_STATUS_INTERNAL_ERROR:
return "CUSOLVER_STATUS_INTERNAL_ERROR";
case CUSOLVER_STATUS_MATRIX_TYPE_NOT_SUPPORTED:
return "CUSOLVER_STATUS_MATRIX_TYPE_NOT_SUPPORTED";
case CUSOLVER_STATUS_NOT_SUPPORTED:
return "CUSOLVER_STATUS_NOT_SUPPORTED ";
case CUSOLVER_STATUS_ZERO_PIVOT:
return "CUSOLVER_STATUS_ZERO_PIVOT";
case CUSOLVER_STATUS_INVALID_LICENSE:
return "CUSOLVER_STATUS_INVALID_LICENSE";
default:
return "UNKNOWN_ERROR";
// Custom CUDA kernel (simple operation)
__global__ void myKernel(cuComplex *data, int N) {
int idx = threadIdx.x + blockDim.x * blockIdx.x;
if (idx < N) {
data[idx].x += 1.0f;
int main() {
const int m = 3;
cudaStream_t stream;
cusolverDnHandle_t cusolverH;
CHECK_CUDA(cudaStreamCreate(&stream));
CHECK_CUSOLVER(cusolverDnCreate(&cusolverH));
CHECK_CUSOLVER(cusolverDnSetStream(cusolverH, stream));
CHECK_CUDA(cudaStreamBeginCapture(stream, cudaStreamCaptureModeGlobal));
cudaGraph_t graph;
cudaGraphExec_t graphExec;
cuFloatComplex *d_work;
int *devInfo;
int lwork = 0;
cuFloatComplex *m_eigen_vec, *m_eigen_vec_row_majored;
float *m_eigen_value;
CHECK_CUDA(cudaMallocAsync(&m_eigen_vec, m*m*sizeof(cuFloatComplex), stream));
CHECK_CUDA(cudaMallocAsync(&m_eigen_vec_row_majored, m*m*sizeof(cuFloatComplex), stream));
CHECK_CUDA(cudaMallocAsync(&m_eigen_value, m*sizeof(float), stream));
CHECK_CUDA(cudaMallocAsync(&devInfo, sizeof(int), stream));
CHECK_CUSOLVER(cusolverDnCheevd_bufferSize(cusolverH, CUSOLVER_EIG_MODE_VECTOR, CUBLAS_FILL_MODE_UPPER, m, m_eigen_vec, m, m_eigen_value, &lwork));
CHECK_CUDA(cudaMallocAsync(&d_work, lwork * sizeof(cuFloatComplex), stream));
cuFloatComplex h_A[m * m] = {
{1, 0}, {2, 0}, {3, 0},
{2, 0}, {5, 0}, {6, 0},
{3, 0}, {6, 0}, {9, 0}
cuFloatComplex *d_A;
CHECK_CUDA(cudaMallocAsync(&d_A, m * m * sizeof(cuFloatComplex), stream));
CHECK_CUDA(cudaMemcpyAsync(d_A, h_A, m * m * sizeof(cuFloatComplex), cudaMemcpyHostToDevice, stream));
// NODE A: EVD
CHECK_CUDA(cudaMemcpyAsync(m_eigen_vec, d_A, m * m * sizeof(cuFloatComplex), cudaMemcpyDeviceToDevice, stream));
CHECK_CUSOLVER(cusolverDnCheevd(cusolverH, CUSOLVER_EIG_MODE_VECTOR, CUBLAS_FILL_MODE_UPPER, m, d_A, m, m_eigen_value, d_work, lwork, devInfo));
// NODE B: My Kernel
int blockSize = 32;
int gridSize = (m * m + blockSize - 1) / blockSize;
myKernel<<<gridSize, blockSize, 0, stream>>>(d_A, m * m);
CHECK_CUDA(cudaStreamEndCapture(stream, &graph));
CHECK_CUDA(cudaGraphInstantiate(&graphExec, graph, nullptr, nullptr, 0));
// Clean up
cudaGraphExecDestroy(graphExec);
cudaGraphDestroy(graph);
cudaStreamDestroy(stream);
return 0;
