System: Intel i7 running Ubuntu 12.04
Graphics Card: specifications from deviceQuery
Device 0: "GeForce GTX 650"
CUDA Driver Version / Runtime Version 6.0 / 6.0
CUDA Capability Major/Minor version number: 3.0
Total amount of global memory: 2048 MBytes (2147287040 bytes)
( 2) Multiprocessors, (192) CUDA Cores/MP: 384 CUDA Cores
GPU Clock rate: 1058 MHz (1.06 GHz)
Memory Clock rate: 2500 Mhz
I recently started working with CUDA. I am having the following issues:
- When I compile the codes I get the following warning
nvcc warning : The 'compute_10' and 'sm_10' architectures are deprecated, and may be removed in a future release.
I don’t understand this warning. Looking up online I found that compiling with
-arch=sm_2
flag would not show the warning. It works, however, I don’t understand what is happening. It would be helpful if someone could explain. Is there a permanent solution?
Also, while installing CUDA, I had run
sudo sh -c 'echo "foreign-architecture armhf" >> /etc/dpkg/dpkg.cfg.d/multiarch'
It was unsuccessful however, the CUDA still got installed and works fine. Is this causing issue? How can I revert it? Also, when I do
sudo apt-get update
in my system, I get a huge amount of errors pertaining to armhf.
