CUDA IPC - Virtual Memory API (cuMemImportFromShareableHandle CUDA_ERROR_INVALID_DEVICE ) - CUDA 11.3
I am adapting the cuda sample MemMapIPC into 2 very simple producer / consumer applications. The producer works just find (so it seems), however my consumer application returns a “invalid device ordinal” error when I call cuMemImportFromShareableHandle. I am not sure why, as this call does not take a deviceID parameter. My code is almost identical to the example code, and i verified the file descriptor is passed through the IPC correctly, so my shareableHandles vector looks accurate. Any insight or suggestions to further debug as to why cuMemImportFromShareableHandle would return CUDA_ERROR_INVALID_DEVICE = 101 ?
Producer: Creates, Shares, and also accesses the the device mem to put some data in it
  • cuMemCreate to allocate
  • cuMemExportToShareableHandle to create the fd
  • cuMemAddressReserve to reserve virtual address space
  • cuMemMap to map for access
  • cuMemSetAccess to set permissions
  • copies some host data into the memory
  • goes to sleep for 30 seconds
Consumer: Gets the fd via IPC, maps the memory, and accesses the data
  • cuMemMap to map for us
  • cuMemImportFromShareableHandle to turn the int fd back into CUDA IPC Handles
  • runs kernel to print some data
Bill
Ubuntu 20.04
%nvidia-smi
Thu Apr 22 20:09:06 2021
| NVIDIA-SMI 465.19.01 Driver Version: 465.19.01 CUDA Version: 11.3 |
| | | MIG M. |
| 0 NVIDIA A100-PCI… On | 00000000:39:00.0 Off | 0 |
| N/A 32C P0 44W / 250W | 4MiB / 40536MiB | 0% Default |
| | | Disabled |
| 1 NVIDIA A100-PCI… On | 00000000:3C:00.0 Off | 0 |
| N/A 32C P0 43W / 250W | 4MiB / 40536MiB | 0% Default |
| | | Disabled |
Attached is a complete example demonstrating the issue i am observing.
  • simple-mmap-prod-con.tar.gz
  • md5sum: 3a29415ec0696b88d29b48b776d25f2b
simple-mmap-prod-con.tar.gz (12.0 KB)
After spending some time with the MemMapIPC example, I realize it may not fit my use case.
The file descriptors generated by cuMemExportToShareableHandle into ShareableHandle are local to your process space, and can be viewed under /proc/pid/fd linked to /dev/nvidiactl
They are not, by themselves, shareable across process space bounds. Process B would need knowledge of Process A PID and access to /proc/pid-a/ filesystem
The example uses unix CMSG sendmsg / recvmsg with SCM_RIGHTS to recreate the file descriptors in process B with the system command dup.
Im not sure what magic happens in the device driver to map these back into CUDA Device Memory Handles.
Since my use case involves using host shared memory as as a means to share IPC handles between a producers and many dockerized consumer processes that are unaware of the producer process, it looks like this example is not a good starting point for me.
I have an existing implementation based on cudaIpcGetMemHandle , and it seems i am sticking with that for now… unless there is a way to use those handles with the new API functions (i.e. cuAddressReserve, cuMemMap )…
Wrt to that, are CUmemGenericAllocationHandle the same as cudaIpcGetMemHandle ?
Bill
I got the same CUDA_ERROR_INVALID_DEVICE when calling cuMemImportFromShareableHandle from the same process that exported it. (I acknowledge that’s a weird usecase).
Still, you point out that this call doesn’t work across process address spaces, which is a glaring gap in the documentation. But my observation shows the same error even when called from the same thread in the same address space.
The only common thread here is docker. Perhaps that causes driver issues?
Hello, did this problem solved? If solved, can you share the solution to me, thanks!
Same problem. Is there any solution now?
Need to use UNIX domain sockets (AF_UNIX) combined with the SCM_RIGHTS mechanism enable the transfer of file descriptors. Please refer to unix(7) - Linux manual page which describe how to send a file descriptor by SCM_RIGHTS.
Commonly, this operation is referred to as "passing a file
descriptor" to another process.  However, more accurately,
what is being passed is a reference to an open file
description (see open(2)), and in the receiving process it
is likely that a different file descriptor number will be
used.  Semantically, this operation is equivalent to
duplicating (dup(2)) a file descriptor into the file
descriptor table of another process.
Share memory just send integer value fd, so it doesn’t work.
