I type make in the SDK directory I got the error that -lGL isn’t found. I found that I’ve to add the symlink libGL.so to /usr/lib. It seems that the nvidia driver deletes this symlink.
But I still have problems, I followed the instructions (here and I tried other sets), but I still have problems.
I tried to compile many of the examples, even the simplest one I think, “alignedTypes” for example and I get:
/usr/bin/ld: cannot find -lcutil
collect2: ld returned 1 exit status
And I verified that the library “cutil” is installed. Also installing the driver from Nvidia site makes problem, I think that the restricted drivers proposed the Ubuntu (version 180) is more adapted; I have a Nvidia GeForce 8600 GS.
I made trials for two days of interned proposal, I tried to downgrade to Ubuntu 8.10, but nothing works.
I was able to install CUDA 2.1 on my Kubuntu 9.04 64 bit (kernel 2.6.28-11) using 180.51 nvidia drivers and downgrading gcc and g++ to 4.2.4 version.
If I try to compile non-GUI SDK examples (e.g. MonteCarlo, deviceQuery, ecc.) I have no problems and all works well, but when I compile programs that require GL, I receive this error:
In file included from particles.cpp:43:
../../common/inc/GL/glew.h:1123:20: error: GL/glu.h: No such file or directory
particles.cpp: In function ‘void reshape(int, int)’:
particles.cpp:257: error: ‘gluPerspective’ was not declared in this scope
make: *** [obj/release/particles.cpp.o] Error 1
Indeed, in folder NVIDIA_CUDA_SDK/common/inc/GL the header file glu.h is not present. What I need to do?
We recently upgraded to 9.04 and (for reasons unrelated to CUDA development) installed kernel 2.6.28-11-server. As a result, the driver is not loading properly any longer. I’ve tried both 180 and the newer 185 version.
Has anyone tried the server kernel and made it work? Is there a known reason why this is not a good idea?
Yes, I should have mentioned that… The errors were during install:
WARNING: You appear to be using a modular X.Org release, but the X
library installation path, 'X: warning; process set to priority -2
instead of
requested priority
0
/usr/lib’, reported by /usr/bin/X -showDefaultLibPath
does not exist. Please check your X.Org installation.
And one similar one. Of course /usr/lib exists.
The other errors were in /var/log/Xorg.0.log:
(II) Loading extension DRI2
(II) LoadModule: "nvidia"
(WW) Warning, couldn't open module nvidia
(II) UnloadModule: "nvidia"
(EE) Failed to load module "nvidia" (module does not exist, 0)
(EE) No drivers available.
Fatal server error:
no screens found
Yet when I do I modprobe nvidia it does in fact load the driver, yet there are no /dev/nv* devices present.
Using above steps in the 1st post, I was able to install Cuda 2.2 on Ubuntu 9.04 (only SDK & toolkit, no Nvidia driver installed as don’t have CUDA h/w, gcc 4.3, glibc 2.9) and able to build all the samples in the SDK with emu=1. Tried running some with emulator and they ran fine (no more cudaSafeCall or cudaMemCpy error).
i finally managed to install the cuda toolkit and SDK (2.2) on Linux 9.04, but when i try to run any sample i built it says:
In fact i can’t find the file in the whole system… how should i install it?
EDIT: i found it in usr/local/cuda/lib and i made a link into usr/lib… now most of the demo work, but it says “cudaSafeCall not yet implemented” and “cudaGLRegisterResource not yet implemented” on some demos.
And how i can add NVCC into the terminal commands? When i try to call it, it is not found.
You might want to run `apt-get -f install’ to correct these:
The following packages have unmet dependencies:
freeglut3-dev: Depends: libxt-dev but it is not going to be installed
Depends: libxext-dev but it is not going to be installed
libx11-dev: Depends: libx11-6 (= 2:1.1.5-2) but 2:1.1.99.2-1ubuntu2 is to be installed
Depends: libxau-dev (>= 1:1.0.0-1) but it is not going to be installed
Depends: libxdmcp-dev (>= 1:1.0.0-1) but it is not going to be installed
Depends: x11proto-core-dev (>= 6.8.99.8-1) but it is not going to be installed
Depends: x11proto-input-dev but it is not going to be installed
Depends: x11proto-kb-dev but it is not going to be installed
Depends: xtrans-dev but it is not going to be installed
Depends: libxcb-xlib0-dev but it is not installable
libxmu-dev: Depends: libxext-dev but it is not going to be installed
Depends: libxmu-headers (= 2:1.0.4-1) but it is not going to be installed
i have downloaded the following dependencies but im not able to install them via the GUI or console in kubuntu 9.04…how to install them??
do i need to copy them somewhere and run “sudo apt-get install libglut3-dev”…
