I am using Ubuntu Edgy and the install went smoothly, but upon attempting to make the examples and common files I get an error as follows:
make[1]: Entering directory `/home/george/NVIDIA_CUDA_SDK/common'
g++ -m32 -W -Wall -Wimplicit -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wmultichar -Wtrigraphs -Wpointer-arith -Wcast-align -Wreturn-type -Wno-unused-function -I. -I/usr/local/cuda/include -I./../common/inc -DUNIX -O3 -o ../bin/obj/release/error_checker.cpp_o -c src/error_checker.cpp
src/error_checker.cpp:51:19: error: GL/gl.h: No such file or directory
src/error_checker.cpp:52:20: error: GL/glu.h: No such file or directory
src/error_checker.cpp: In static member function ‘static void ErrorChecker::checkErrorGL(const char*, int)’:
src/error_checker.cpp:64: error: ‘GLenum’ was not declared in this scope
src/error_checker.cpp:64: error: expected `;' before ‘gl_error’
src/error_checker.cpp:65: error: ‘gl_error’ was not declared in this scope
src/error_checker.cpp:65: error: ‘GL_NO_ERROR’ was not declared in this scope
src/error_checker.cpp:69: error: ‘gluErrorString’ was not declared in this scope
make[1]: *** [../bin/obj/release/error_checker.cpp_o] Error 1
make[1]: Leaving directory `/home/george/NVIDIA_CUDA_SDK/common'
make: *** [lib/libcutil.so] Error 2
The two files just don’t exist in my common/inc/GL folder, where (judging by the code) I assume it is looking for them. After looking through the extraction log the gl.h and glu.h were never extracted, and I’m not sure why. I’m guessing the problem is deeper but I cant figure out where it is.
It is pretty essential as well, as error_checker is included in cutil, which is included in all examples.
As background I have a 8800gts in the mail, so I ran the command in the SDK folder:
EDIT: Re-install of mesa-common-dev fixed it. Thanks a lot.
If anyone has the same problem (this was a pretty fresh install of Ubuntu, so people might)
just do the following:
sudo apt-get install --reinstall mesa-common-dev
EDIT: Next problem >.<
In file included from ../../common/inc/GL/glh_genext.h:16,
from ../../common/inc/GL/glh_extensions.h:49,
from simpleGL.cu:53:
/usr/include/GL/glx.h:38:22: error: X11/Xlib.h: No such file or directory
/usr/include/GL/glx.h:39:23: error: X11/Xutil.h: No such file or directory
In file included from simpleGL.cu:55:
../../common/inc/GL/glut.h:64:1: warning: "APIENTRY" redefined
In file included from ../../common/inc/GL/glh_extensions.h:31,
/usr/include/GL/gl.h:104:1: warning: this is the location of the previous definition
I’ll poke around with it for a while see if I can find a solution.
I think I’m slowly getting closer… Next problem: :">
This one might be due to the fact that I dont have the graphics driver installed as I am still waiting for my processor. Emulating the samples already works fine, so if this is just driver problems then I am a happy camper. Regardless, here is the message
It shows a bunch of the same errors at different lines in:
This is some interaction between the OpenGL headers on Ubuntu and the Nvidia drivers. If you don’t care about using CUDA with OpenGL, you can ignore this problem and your generic CUDA code will work fine. Otherwise, I don’t think this is a CUDA-specific issue, so googling for OpenGL and glXGetProcAddressARB might give you some pointers…
I am facing a similar problem trying to make the CUDA SDK 1.1 on an FC5 machine with the 2.6.15-1.2054_FC5smp kernel.
i have gl.h installed in /usr/include/GL but there is no glu.h on the system. due to this i am getting an error while doing a make of CUDA SDK 1.1 in the emulation and debug mode.
i have lots of *mesa.h files in the /usr/include/GL as well. only the glu.h file looks like missing.
[adimax@rahu NVIDIA_CUDA_SDK]$ make emu=1 dbg=1
make[1]: Entering directory `/home/adimax/dumpdata/NVIDIA_CUDA_SDK/common'
ar: creating ./../lib/libcutilD.a
a - obj/debug/bank_checker.cpp_o
a - obj/debug/cmd_arg_reader.cpp_o
a - obj/debug/cutil.cpp_o
a - obj/debug/stopwatch.cpp_o
a - obj/debug/stopwatch_linux.cpp_o
a - obj/debug/multithreading.cpp_o
make[1]: Leaving directory `/home/adimax/dumpdata/NVIDIA_CUDA_SDK/common'
In file included from ./../common/inc/paramgl.h:13,
from src/paramgl.cpp:8:
./../common/inc/GL/glut.h:60:20: error: GL/glu.h: No such file or directory
In file included from ./../common/inc/GL/glut.h:59,
make[1]: *** [obj/debug/paramgl.cpp_o] Error 1
make: *** [lib/libparamgl.so] Error 2
[adimax@rahu NVIDIA_CUDA_SDK]$ cd common/inc/
Thanks again for your help.
-George
[snapback]170680[/snapback]
[/quote]
Also, you might want to install the “freeglut”-package…
This is just a guess, but maybe to use CUDA you should install nvidia-glx-177-dev (Or whichever driver revision you have) which is nvidia’s OpenGL libraries and headers.
Then, as stated before, use libglu1-mesa-dev for GLU.
replace “toolkit” with “SDK” and that’s a legitimate question. freeglut has nothing to do with the toolkit, just some SDK samples (same with D3D support for the Windows SDK).
I get an error “GL/glu.h No such file or directory” on Ubuntu 8.10, and I tried all the advice I found in this thread. Nothing helps.
Namely, I tried
yum install freeglut freeglut-devel libX11-devel mesa-libGLU-devel
etc.
and I don’t have libGLU/glu.h in /usr/include.
I’m running Debian, so not too far from Ubuntu. I installed the following packages (apt-get install) this morning, and everything compiles fine for me:
