CUDA Profiler Tools Interface (CUPTI) 13.4 is now available for download in the NVIDIA Registered Developer Program.
The NVIDIA CUDA Profiler Tools Interface (CUPTI), distributed as part of the CUDA Toolkit, is a library that enables the creation of profiling and tracing tools that target CUDA applications. CUPTI provides a set of APIs targeted at ISVs creating profilers and other performance optimization tools:- the Activity API,
- the Callback API,
- the Host Profiling API,
- the Range Profiling API,
- the PC Sampling API,
- the SASS Metric API,
- the PM Sampling API,
- the Checkpoint API,
- the Profiling API,
- the Python API (available separately)
Updates in CUDA Toolkit 13.4 Update 1
Resolved Issues
Fixed unbounded CPU utilization growth during long-running activity tracing, improving performance stability for continuous GPU workload tracing.
Fixed a race condition in CUPTI HES mode that caused intermittent crashes during cudaGraphInstantiate by properly synchronizing related operations.
Fixed a memory leak when HES is enabled that caused approximately 100 bytes of host memory to leak per kernel activity record.
Fixed a system crash and intermittent zero-valued timestamps in HES mode during concurrent context destruction.
Fixed a deadlock in kernel latency timestamp collection that could occur when a device buffer was allocated during kernel launch.
Fixed stale kernel names in activity records after module reloads.
New Features
Added support for the Rubin GPU architecture.
Fixed Clock Rate - Added APIs
cuptiClockControlLock()andcuptiClockControlUnlock()withCUPTI_CLOCK_CONTROL_MODE_BASEorCUPTI_CLOCK_CONTROL_MODE_BOOSTto lock GPU clocks and eliminate clock-rate variability during profiling. Refer to the section Fixed Clock Rate for more details.Cache State Reset - Range Profiler can now reset L2 (or all) cache before each replay pass via the
cacheControlModefield inCUpti_RangeProfiler_Enable_Params. Refer to the section Cache State Reset for more details.Added
sourceGraphIdto provide the unique graph ID of the node from which the kernel node was instantiated or last updated andsourceGraphNodeIdwhich provides unique graph node ID of the node from which the kernel node was instantiated or last updated. The activity recordCUpti_ActivityKernel12is deprecated and replaced byCUpti_ActivityKernel13.To ensure tracing and profiling accuracy, live vGPU migration is blocked while CUPTI is active and resumes only after
cuptiFinalize()is called or the process exits.Added
workqueueChannelCountandworkqueueChannelIdsfields to the green context activity record to report the number of HW channels assigned to a green context s work queue and their channel IDs, respectively. The activity recordCUpti_ActivityGreenContext2is deprecated and replaced byCUpti_ActivityGreenContext3.CUPTI library installation path: For Windows, libraries are now placed under architecture-specific directories instead of the generic lib64 folder to support proper cross-compile support. For ex: on a x86_64 system, the CUPTI libraries are installed under C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA<version>\extras\CUPTI\lib\x64.
Per-subscriber timestamp callback registration via
CUPTI_ACTIVITY_ATTR_TIMESTAMP_CALLBACKusingcuptiActivitySetAttribute_v2is now supported in multi-subscriber mode, allowing tools to register their own callbacks rather than sharing a common callback.Fixed issues that could occur after disabling user-defined records via the
CUPTI_ACTIVITY_ATTR_USER_DEFINED_RECORDSattribute.Fixed an issue that sometimes causes a brief (~2 s) CUPTI block when disabling the
CUPTI_ACTIVITY_KIND_UNIFIED_MEMORY_COUNTERactivity.Fixed a host heap corruption issue that could occur when using CUPTI HES trace (
cuptiActivityEnableHWTrace).Fixed CUPTI HES activity so that
graphNodeIdfield retains the full graphId (upper 32-bits) in CUDA-graph memory copy records.
Resolved Issues
Getting Started
For more information on CUPTI for CUDA Toolkit 13.4 , including features, requirements, documentation and support, please visit the CUPTI Overview page.
To download this version, get it as part of the CUDA Profiler Tools Interface (CUPTI) for CUDA Toolkit 13.4.
Version 2026.3.0 Overview & New Features | Download | Documentation
For more information on CUPTI Python
Please refer to the CUPTI Python for CUDA Toolkit 13.3.0 overview,
Latest PRODUCT INFO
- Overview (download, features, platforms, requirements)
- Documentation
- Downloads (as part of CUDA Toolkit)
- Downloads (outside of CUDA Toolkit)
- Revision History
- CUPTI Forum
