• Hardware Platform Jetson
• DeepStream Version 7.1.0
• JetPack Version 6.2
• TensorRT Version 10.3
• Issue Type questions, bug
• When I use apply_image_processing,which is the function defined by myself, its seems to fail to initialize correctly every time.(The output result seems to be that the input of this function is the processing result of this function last time)
I use gstreamer to do the image processing for each frame of RTSP stream.
pipline is
"( rtspsrc location=" + std::string(SOURCE_RTSP_URI) + " latency=0 ! "
"application/x-rtp, media=video, payload=96, encoding-name=H265 ! "
"rtph265depay ! h265parse ! "
"nvv4l2decoder latency=10 ! "
"nvvidconv name=format_conv format=NV12 ! "
"queue max-size-buffers=10 ! "
"identity name=stats_identity ! "
"nvv4l2h265enc insert-sps-pps=true bitrate=4000000 ! "
"h265parse ! "
"rtph265pay name=pay0 pt=96 config-interval=-1 )"
callback function handoff_handler is in the identity
static void handoff_handler(GstElement* identity, GstBuffer* buffer, GstPad* pad, gpointer user_data) {
// 确保 CUDA 设备已初始化
static bool cuda_initialized = false;
if (!cuda_initialized) {
cudaSetDevice(0);
// cudaFree(0);
cuda_initialized = true;
// 打印内存信息
size_t free_memory, total_memory;
cudaMemGetInfo(&free_memory, &total_memory);
printf("GPU Memory: %zu MB free, %zu MB total\n", free_memory / (1024 * 1024), total_memory / (1024 * 1024));
frame_count++;
gint64 current_time = g_get_monotonic_time();
// FPS计算
if (current_time - last_print_time > G_USEC_PER_SEC) {
gdouble fps = (gdouble)frame_count * G_USEC_PER_SEC / (current_time - last_print_time);
printf("FPS: %.2f\n", fps);
frame_count = 0;
last_print_time = current_time;
// 从 GstBuffer 获取 NvBufSurface
NvBufSurface* surf = nullptr;
// 获取 NvBufSurface
GstMapInfo map_info;
if (!gst_buffer_map(buffer, &map_info, GST_MAP_READWRITE)) {
printf("Failed to map buffer\n");
return;
// 获取 NvBufSurface 指针
surf = (NvBufSurface*)map_info.data;
if (!surf || surf->numFilled <= 0) {
printf("Failed to get NvBufSurface\n");
gst_buffer_unmap(buffer, &map_info);
return;
// 打印bufer信息
int p;
printf("identity->surf : \n");
printf(" batchSize = %d\n", surf->batchSize);
printf(" numFilled = %d\n", surf->numFilled);
printf(" memType = %d\n", surf->memType);
for (int bs = 0; bs < surf->batchSize; bs++) {
NvBufSurfaceParams *sur = &(surf->surfaceList[bs]);
if (sur == NULL)
break;
printf(" surfaceList[%d]:\n", bs);
printf(" width = %d\n", sur->width);
printf(" height = %d\n", sur->height);
printf(" pitch = %d\n", sur->pitch);
printf(" layout = %d\n", sur->layout);
printf(" colorFormat = %d\n", sur->colorFormat);
printf(" bufferDesc = %lu\n", sur->bufferDesc);
printf(" dataSize = %d\n", sur->dataSize);
printf(" dataPtr = %p\n", sur->dataPtr);
if(sur->colorFormat == NVBUF_COLOR_FORMAT_NV12_ER)
printf("it's NVBUF_COLOR_FORMAT_NV12_ER!\n");
else
printf("it's not NVBUF_COLOR_FORMAT_NV12_ER(%d)\n", NVBUF_COLOR_FORMAT_NV12_ER);
NvBufSurfacePlaneParams *planeParams = &(sur->planeParams);
printf(" NvBufSurfaceParams->planeParams:\n");
printf(" num_planes = %d\n", planeParams->num_planes);
for (p = 0; p < planeParams->num_planes; p++) {
printf(" width[%d] = %u\n", p, planeParams->width[p]);
printf(" height[%d] = %u\n", p, planeParams->height[p]);
printf(" pitch[%d] = %u\n", p, planeParams->pitch[p]);
printf(" offset[%d] = %u\n", p, planeParams->offset[p]);
printf(" psize[%d] = %u\n", p, planeParams->psize[p]);
printf(" bytesPerPix[%d] = %u\n", p, planeParams->bytesPerPix[p]);
NvBufSurfaceMappedAddr *mAddr = &(sur->mappedAddr);
printf(" NvBufSurfaceParams->mappedAddr:\n");
for (p = 0; p < NVBUF_MAX_PLANES; p++) {
if (!mAddr->addr) {
printf(" mappedAddr->addr[%d] is NULL\n", p);
break;
printf(" mappedAddr->addr[%d] = %p\n", p, mAddr->addr[p]);
if (mAddr->eglImage == NULL)
printf(" mappedAddr->eglImage is NULL\n");
else
printf(" mappedAddr->eglImage is %p\n", mAddr->eglImage);
// ---------------------------------------------------------------------------- CUDA 版本 ---------------------------------------------------------------------------------
// map EGLImage
if (NvBufSurfaceMapEglImage(surf, 0) != 0) {
printf("Failed to map EGLImage");
return;
// 从 surf 结构中获取Y平面 EGLImage
EGLImageKHR egl_image_y = surf->surfaceList[0].mappedAddr.eglImage;
if (egl_image_y == EGL_NO_IMAGE_KHR) {
printf("EGLImage is NULL after mapping\n");
NvBufSurfaceUnMapEglImage(surf, 0);
return;
// 使用CUDA接口注册EGLImage
CUgraphicsResource cuResource;
CUresult cuRes = cuGraphicsEGLRegisterImage(&cuResource, egl_image_y, CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
if (cuRes != CUDA_SUCCESS) {
printf("cuGraphicsEGLRegisterImage failed: %d\n", cuRes);
return;
printf("CUDA EGL registration successful\n");
// 映射CUDA资源
CUeglFrame egl_frame_y;
cuRes = cuGraphicsResourceGetMappedEglFrame(&egl_frame_y, cuResource, 0, 0);
printf("cuGraphicsResourceGetMappedEglFrame failed with error code %d\n", cuRes);
cuGraphicsUnmapResources(1,&cuResource,0);
cuGraphicsUnregisterResource(cuResource);
return;
printf("cuGraphicsResourceGetMappedEglFrame successful\n");
printf(" frame.width = %d\n", egl_frame_y.width);
printf(" frame.height = %d\n", egl_frame_y.height);
// 获取 cuArray
CUarray cuArray_y = egl_frame_y.frame.pArray[0];
int width = surf->surfaceList[0].width;
int height = surf->surfaceList[0].height;
// 打印调试信息
printf("CUDA Array: %p\n", (void*)cuArray_y);
printf("Image dimensions: %d x %d\n", width, height);
// 控制标志
bool applyClahe = true;
bool applyBrightness = false;
float clipLimit = 0.1f;
int tileGridX = 8, tileGridY = 8;
float brightnessFactor = 1.5f;
// 调用统一处理函数
cudaError_t process_err = apply_image_processing(&cuArray_y, width, height, applyClahe, applyBrightness, clipLimit, tileGridX, tileGridY, brightnessFactor);
if (process_err != cudaSuccess) {
printf("Image processing failed: %s\n", cudaGetErrorString(process_err));
// --------------------------------------------------------------- CUDA end --------------------------------------------------------------------------------
// 同步设备
cudaDeviceSynchronize();
cuRes = cuGraphicsUnmapResources(1, &cuResource, 0);
printf("Unmap failed: %d\n", cuRes);
cuRes = cuGraphicsUnregisterResource(cuResource);
printf("cuGraphicsUnregisterResource failed: %d\n", cuRes);
if (NvBufSurfaceUnMapEglImage(surf, 0) != 0) {
printf("NvBufSurfaceUnMapEglImage failed\n");
The bash output(the following output is the output for processing one frame) is
GPU Memory: 25891 MB free, 30697 MB total
identity->surf :
batchSize = 1
numFilled = 1
memType = 4
surfaceList[0]:
width = 5120
height = 1440
pitch = 5120
layout = 1
colorFormat = 7
bufferDesc = 61
dataSize = 11796480
dataPtr = 0xffff380632b0
num_planes = 2
width[0] = 5120
height[0] = 1440
pitch[0] = 5120
offset[0] = 0
psize[0] = 7864320
bytesPerPix[0] = 1
width[1] = 2560
height[1] = 720
pitch[1] = 5120
offset[1] = 7864320
psize[1] = 3932160
bytesPerPix[1] = 2
mappedAddr->addr[0] = (nil)
mappedAddr->addr[1] = (nil)
mappedAddr->addr[2] = (nil)
mappedAddr->addr[3] = (nil)
frame.width = 5120
frame.height = 1440
CUDA Array: 0xffff7494b800
Image dimensions: 5120 x 1440
===== Starting Image Processing =====
Image size: 5120 x 1440
Apply CLAHE: YES
Apply Brightness: NO
CLAHE parameters:
Clip limit: 0.10
Tile grid: 8 x 8
[CLAHE] Starting processing for 5120x1440 image
[CLAHE] Tile configuration: 8x8 tiles
[CLAHE] Clip limit: 0.10
[CLAHE] Tile size: 640x180 pixels
[CLAHE] Total tiles: 64
[CUDA] Using CUDA array: 0xffff7494b800
[CUDA] Texture object created: 0x1 (0.00 ms)
[CUDA] Surface object created: 0x2 (0.01 ms)
[MEM] Allocating histogram: 0.06 MB
[MEM] Histogram allocated: 0x205ce0000 (0.21 ms)
[MEM] Allocating CDF: 0.06 MB
[MEM] CDF allocated: 0x205cf0000 (0.01 ms)
[INIT] Zeroing histogram and CDF memory
[INIT] Histogram and CDF zeroed (0.06 ms)
[KERNEL] Launching computeHistogramKernel
Grid: (8, 8, 1)
Block: (256, 1, 1)
Shared memory: 1024 bytes
[KERNEL] computeHistogramKernel completed (0.50 ms)
[KERNEL] Launching clipAndComputeCDFKernel
Grid: (1, 1, 1)
Block: (256, 1, 1)
[KERNEL] clipAndComputeCDFKernel completed (0.28 ms)
[KERNEL] Launching applyEqualizationKernel
Grid: (320, 90, 1)
Block: (16, 16, 1)
[KERNEL] applyEqualizationKernel completed (0.78 ms)
[CLEANUP] Releasing resources
[CLEANUP] Resources released (0.22 ms)
[CLAHE] Processing completed successfully
Total processing time: 0.003 seconds
===== Image Processing Complete =====
Unmap failed: 999
