CUDA Driver Version: 11.0
CUDA runtime version: 10.1.243
I found CUDA driver version using nvidia-smi command is 11.0. Depending on this version I installed compatible PyTorch using the command conda install pytorch==1.7.1 torchvision==0.8.2 torchaudio==0.7.2 cudatoolkit=11.0 -c pytorch. Now, if I run the command torch.cuda.is_available() to check the availability of CUDA it returns False.
I also ran the command !python -m torch.utils.collect_env to collect the environment information which returned:
Collecting environment information...
/home/user/anaconda3/envs/tf-gpu/lib/python3.6/site-packages/torch/cuda/__init__.py:52: UserWarning: CUDA initialization: CUDA unknown error - this may be due to an incorrectly set up environment, e.g. changing env variable CUDA_VISIBLE_DEVICES after program start. Setting the available devices to be zero. (Triggered internally at /opt/conda/conda-bld/pytorch_1607370120218/work/c10/cuda/CUDAFunctions.cpp:100.)
return torch._C._cuda_getDeviceCount() > 0
PyTorch version: 1.7.1
Is debug build: False
CUDA used to build PyTorch: 11.0
ROCM used to build PyTorch: N/A
OS: Ubuntu 20.04.1 LTS (x86_64)
GCC version: (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
Clang version: Could not collect
CMake version: version 3.16.3
Python version: 3.6 (64-bit runtime)
Is CUDA available: False
GPU models and configuration: GPU 0: GeForce RTX 2070 SUPER
Nvidia driver version: 450.119.03
cuDNN version: Could not collect
HIP runtime version: N/A
MIOpen runtime version: N/A
Versions of relevant libraries:
[pip3] numpy==1.19.2
[pip3] torch==1.7.1
[pip3] torchaudio==0.7.0a0+a853dff
[pip3] torchvision==0.8.2
[conda] blas 1.0 mkl
[conda] cudatoolkit 11.0.221 h6bb024c_0
[conda] mkl 2020.2 256
[conda] mkl-service 2.3.0 py36he8ac12f_0
[conda] mkl_fft 1.3.0 py36h54f3939_0
[conda] mkl_random 1.1.1 py36h0573a6f_0
[conda] numpy 1.19.2 py36h54aff64_0
[conda] numpy-base 1.19.2 py36hfa32c7d_0
[conda] pytorch 1.7.1 py3.6_cuda11.0.221_cudnn8.0.5_0 pytorch
[conda] torchaudio 0.7.2 py36 pytorch
[conda] torchvision 0.8.2 py36_cu110 pytorch
I would like to know which PyTorch version I need to install in the conda environment to access the CUDA? Is it depending on CUDA runtime version(10.1.243) or CUDA driver version (11.0)?
Thank you.
