I’m using Ubuntu 20 and CUDA 11.1
I followed the steps in here: https://developer.nvidia.com/blog/nvidia-docker-gpu-server-application-deployment-made-easy/
When I got to sudo nvidia-docker build -t device-query ., it says
unable to locate package cuda-samples
the command '/bin/sh -c apt-get update && apt-get install -y --no-install-recommends
cuda-samples:-$CUDA_PKG_VERSION && -rm -rf /var/lib/apt/lists/*'
returned a non-zero code: 100
The Dockerfile is:
# FROM defines the base image
FROM nvidia/cuda
# RUN executes a shell command
# You can chain multiple commands together with &&
# A \ is used to split long lines to help with readability
# This particular instruction installs the source files
# for deviceQuery by installing the CUDA samples via apt
RUN apt-get update && apt-get install -y --no-install-recommends \
cuda-samples-$CUDA_PKG_VERSION && \
# set the working directory
WORKDIR /usr/local/cuda-11.1/samples/1_Utilities/deviceQuery
RUN make
# CMD defines the default command to be run in the container
# CMD is overridden by supplying a command + arguments to
# `docker run`, e.g. `nvcc --version` or `bash`
CMD ./deviceQuery
can anyone help?
