Running with the following:
My Dockerfile:
FROM nvidia/cuda:10.1-devel-ubuntu18.04
ENV DEBIAN_FRONTEND=noninteractive
WORKDIR /opt/memtest
RUN apt-get update \
&& apt-get install -y --no-install-recommends \
curl \
&& rm -rf /var/lib/apt/lists/* \
&& curl -s -S -L https://github.com/ForkLab/cuda_memtest/archive/refs/heads/dev.tar.gz \
| tar -xzf - --strip-components=1
RUN make CFLAGS="-arch compute_50 -DSM_50 -O3"
Built with sudo docker build -t memtest .
Output of sudo docker run --gpus all --rm -it memtest nvidia-smi:
| NVIDIA-SMI 418.211.00 Driver Version: 418.211.00 CUDA Version: N/A |
| 0 Quadro K620 On | 00000000:01:00.0 Off | N/A |
| 34% 39C P8 1W / 30W | 1MiB / 2002MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
Output of sudo docker run --gpus all --rm -it memtest ./cuda_memtest:
[10/16/2021 16:44:24][411cc62bdc89][0]:Running cuda memtest, version 1.2.3
[10/16/2021 16:44:24][411cc62bdc89][0]:ERROR: CUDA error: CUDA driver version is insufficient for CUDA runtime version, line 283, file cuda_memtest.cu
I don’t understand why this error is happening? I believe the K620 has CUDA compute capability 5.0 which should be sufficient, and my driver 418.211 should be recent enough for the cuda:10.1-devel-ubuntu18.04 image.
