I’m writing implementation of Sieve of Eratosthenes (Sieve of Eratosthenes - Wikipedia) on GPU. But no sth like this - Developer Resource: Cuda - Sieve of Eratosthenes
Method:
- Creating n-element array with default values 0/1 (0 - prime, 1 - no) and passing it on GPU (I know that it can be done directly in kernel but it’s not problem in this moment).
- Each thread in block checks multiples of a single number. Each block checks in total sqrt(n) possibilities. Each block == different interval.
- Marking multiples as 1 and passing data back to the host.
Code:
#include <stdio.h>
#include <stdlib.h>
#define THREADS 1024
__global__ void kernel(int *global, int threads) {
extern __shared__ int cache[];
int tid = threadIdx.x + 1;
int offset = blockIdx.x * blockDim.x;
int number = offset + tid;
cache[tid - 1] = global[number];
__syncthreads();
int start = offset + 1;
int end = offset + threads;
for (int i = start; i <= end; i++) {
if ((i != tid) && (tid != 1) && (i % tid == 0)) {
cache[i - offset - 1] = 1;
__syncthreads();
global[number] = cache[tid - 1];
int main(int argc, char *argv[]) {
int *array, *dev_array;
int n = atol(argv[1]);
int n_sqrt = floor(sqrt((double)n));
size_t array_size = n * sizeof(int);
array = (int*) malloc(n * sizeof(int));
array[0] = 1;
array[1] = 1;
for (int i = 2; i < n; i++) {
array[i] = 0;
cudaMalloc((void**)&dev_array, array_size);
cudaMemcpy(dev_array, array, array_size, cudaMemcpyHostToDevice);
int threads = min(n_sqrt, THREADS);
int blocks = n / threads;
int shared = threads * sizeof(int);
kernel<<<blocks, threads, shared>>>(dev_array, threads);
cudaMemcpy(array, dev_array, array_size, cudaMemcpyDeviceToHost);
int count = 0;
for (int i = 0; i < n; i++) {
if (array[i] == 0) {
count++;
printf("Count: %d\n", count);
return 0;
Run:
./sieve 10240000
It works correctly when n = 16, 64, 1024, 102400… but for n = 10240000 I getting incorrect result. Where is problem?
