So, the 17" Macbook Pro (http://www.apple.com/macbookpro/specs.html) has two NVIDIA chips in it, the 9400M with 256MB of memory and the 9600M GT with 512MB of memory - in normal operation it just has the 9400M on, and leaves the 9600M in reserve for the heavy lifting.
I installed the CUDA SDK and Tools and deviceQuery is only seeing the 9400M and its 256MB of memory. Is there some trick to enabling the 9600M? Is it possible to task both GPUs with CUDA?
Thanks for any guidance.
-eric
arly152:release ericvh$ ./deviceQuery
There is 1 device supporting CUDA
Device 0: “GeForce 9400M”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 266010624 bytes
Number of multiprocessors: 2
Number of cores: 16
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.80 GHz
Concurrent copy and execution: No
Test PASSED
