Hi all,
I’m going to buy a new MB Pro equipped with the NVIDIA 320M gpu. I wonder to know if is it a CUDA capable device. I didn’t found any official information about that. And if has anybody already tested it for CUDA development.
Thank you for any answers
Ric
Hi Ric,
I checked this thread before buying the new macbook pro 13
I couldn’t figure out which was the computer capability of 320M back then…
now finally i bought it, installed cuda (straightforward following the get started guide) 3.0 and run devicequery sample
the output:
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “GeForce 320M”
CUDA Driver Version: 3.0
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 2
Total amount of global memory: 265027584 bytes
Number of multiprocessors: 6
Number of cores: 48
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Clock rate: 0.00 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: Yes
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple
host threads can use this device simultaneously)
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 53931, CUDA
Runtime Version = 3.0, NumDevs = 1, Device = GeForce 320M
PASSED
Press to Quit…
So, YES, it is cuda computing capability 1.2 compatible.
Cheers, happy coding,
ant
