Hello All,
I have built a VS2005 solution using one of the CUDA 2.0 SDK examples as reference. I was trying to use the CUDA visual profiler on this application.
The manual CUDA_profiler_2.0.txt suggests that I rebuild the application after setting the following env variables: CUDA_PROFILE = 1
CUDA_PROFILE_CSV =1
I do that, recompile the application and run but do not find cuda_profile.log or the csv file in the project directory. I doubt that the logfile is being generated. How do I create an input file for the visual profiler? How do I create a cuda project file (.cpj)?
Any help/tips/comments would be greatly appreciated.
I found the answer.
just compile the code in the visual studio. the visual studio creates an .exe . then show this .exe file to the visual profiler than press run. the visual profiler creates the .cpj and .csv files and shows the result.
I can run on 8600 gt.
I used the cuda sdk v 2.0.
I have already create the .exe, and I open visual profiler , and then create a project
in C:/Documents and Settings/James/My Documents/Visual Studio 2005/Projects.
In the launch box , I fill the .exe
“C:/Documents and Settings/James/My Documents/Visual Studio 2005/Projects/CUDAWinApp1/debug/CUDAWinApp1.exe”
Finally, I press start button, it show me a error message as following:
Execution run #1 of program "C:/Documents and Settings/James/My Documents/Visual Studio 2005/Projects/CUDAWinApp1/debug/CUDAWinApp1.exe"failed, exit code: -1073741515
Does anybody know what happend on the steps of executing the visual profiler??
