I have a very long program that I wish to speed up using CUDA/NVIDIA. I have profiled it using the Linux c profiler, but that seems to be somewhat limiting. Sooner or later I will go to the CUDA Viusal profiler. I was wondering if I could use the Cudaprof now to profile this c program that has no CUDA code in it.
I understand that I will get no CUDA outputs, but that is okay, since all I want to know for now is the location of the program’s bottlenecks.
In the future when subprogram(s) are re-written in CUDA, then I will get the CUDA output info. I just want to get used to using the CUDA Visual profiler for now.
I am guessing that I will have to compile using nvcc instead of gcc so that the cuda visual profiler will work on this code. Is this correct?
Newport_j
